Carstedts LSJ round 2
Old Oct 30, 2012 | 10:11 AM
  #101
mrbelvedere's Avatar
Originally Posted by jittjoey
looks good minus the oil cooler...
you wished
Old Oct 30, 2012 | 09:45 PM
  #102
carstedt's Avatar
in case anyone is curious on the size of the zzp s3 axles here ya go
[IMG][/IMG]
Old Oct 30, 2012 | 10:32 PM
  #103
jrmotosports 88's Avatar
you read my mind........... damn...... i must go clean up.....
Old Oct 30, 2012 | 10:57 PM
  #104
Tjolley's Avatar
hmm looks good..so they disable the abs right
Old Oct 30, 2012 | 11:02 PM
  #105
carstedt's Avatar
thats what they say but we shall see
Old Oct 30, 2012 | 11:19 PM
  #106
Tjolley's Avatar
lol...i have brembos on my lsj and abs is a must..lol
Old Oct 30, 2012 | 11:21 PM
  #107
carstedt's Avatar
i just use drilled and slotted, i dont track mine or anything its my DD so abs isnt really important to me
Old Oct 30, 2012 | 11:30 PM
  #108
Tjolley's Avatar
true true...i bolted them on mine cuz i got a good deal...
there isn't anything wrong with the stock lsjs...i want to machine a bracket to put a 13" rotor in there
Old Oct 30, 2012 | 11:32 PM
  #109
carstedt's Avatar
ive thought about doing the brembos a couple times but in the end i just decided for the way the car is driven, the stock ones will do just fine
Old Oct 31, 2012 | 08:47 AM
  #110
armcclure's Avatar
I'll be removing abs module soon. My first car never had working abs so I'm not too worried about it.
Old Oct 31, 2012 | 11:32 AM
  #111
brian.olsson's Avatar
Yeah, I don't know, the hubs for sensors and reluctors in them, maybe they just need to change the settings for the different size reluctor or something I don't know, bit they plugged right up, ill take a look later and see iftheir us any differences I can see
Old Oct 31, 2012 | 01:15 PM
  #112
Tjolley's Avatar
the abs light would come on if the system sees a problem
Old Oct 31, 2012 | 01:21 PM
  #113
Tjolley's Avatar
i planed to build my own next time i break the s1s...they don't like dumping the clutch at 6k in second gear...o the drag strip...lol zzp stage 4 clutch grabs and goes...not much slip
Old Oct 31, 2012 | 01:44 PM
  #114
yeah, and if the rings and stuff are different it see a problem, but I think you can change the pulses per second to fix it, well maybe
Old Oct 31, 2012 | 03:16 PM
  #115
the abs sensor is the wheel bearing its self so unless you have to change to a different bearing it should still work
Old Oct 31, 2012 | 04:20 PM
  #116
jittjoey's Avatar
How much was the adapter for oil pressure with the intercepter ?
Old Oct 31, 2012 | 05:01 PM
  #117
carstedt's Avatar
i think i paid like 55 or 65 for it
Old Oct 31, 2012 | 05:15 PM
  #118
ebristol's Avatar
Impressive work.
Old Oct 31, 2012 | 05:29 PM
  #119
decent guy, no matter what the mods say... lol absolutely sick car, even in my favorite color....
brian great work, everything is so well done... congrats im so jelly......
Old Oct 31, 2012 | 05:38 PM
  #120
carstedt's Avatar
i wasnt able to get any good videos of the car on the last build, but i bought myself a go pro so ill be getting some good videos this time haha
Old Oct 31, 2012 | 05:50 PM
  #121
Powell Race Parts's Avatar
lnf bearings have wrong tooth count for lsj abs. gotta use a grand am wheel bearing, required machining, but accepts bigger axle.
Old Oct 31, 2012 | 06:48 PM
  #122
Tjolley's Avatar
hmm so y not use grand am axles just machine them to use lsj ends...or use grand am spindles and adapt the end to go into the f35 trans.
Old Oct 31, 2012 | 06:50 PM
  #123
Yeah, carstedt got the zzp stage 3 axle kit. It comes with new lower control arms with a bigger ball joint, new spindles with a bigger opening, for the bigger hubs for the axle, it all bolts up nice, but on the zzp site says it disables the abs, but I was looking at the new hubs and I think I can still get the abs to work cause their ate sensors in the hubs, the way zzp made it sound is their were no sensors for abs, so I'm thinking cause its a larger tone ring, or reluctor wheel, whichever you want to call it, if I change the pluses per min, to match what the speed sensor on the transmission is putting out, the abs should work fine
Old Oct 31, 2012 | 06:56 PM
  #124
Thankyou, all it takes is a little paicents, and a lot of cussing and cut up hands lol damn lsj wire harness, so hard to hide
Old Oct 31, 2012 | 10:05 PM
  #125
the mods dont say anything. no different than anyone else in this thread.
