Catback question?
Old Jan 12, 2006 | 07:26 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Catback question?
I finally received my TOG header after a long screwed up delivery and tomorrow I am going in to get a custom exhaust designed. My question is can I just omit the catalytic converter without throwing a CEL code? I am thinking of having the exhaust built so i can reinstall the cat if ever needed. I don't have to have my car tested for 4 more years. What do you more learned tuners think?
Thanks
Old Jan 12, 2006 | 07:30 PM
VaMP's Avatar
There's a few members that are running without the converter without any CEL. Just be warned, if you're caught without it, you can face serious charges pending what state you're in.
Old Jan 12, 2006 | 07:37 PM
eastcoastz's Avatar
I could not see how an OBD 2 vehicle running around without a cat would not throw a code. If I were you just save your downpipe\cat and have a custom catless downpipe made and just swap the 2 when you have to re-inspect.
Old Jan 12, 2006 | 08:03 PM
BooSSted's Avatar
I would advise against it. Your cat is not restrictive enough to really cause you to lose a lot fo power. If you do insist on taking it out though, you can get a clip for the O2 sensor to alter the readings I believe.
Old Jan 13, 2006 | 10:41 AM
GSoccer24's Avatar
yeah you can get an O2 simulator if you throw a code, they're only like $8 or something
Old Jan 13, 2006 | 11:01 AM
Rusty's Avatar
just get a high flow cat to put on....
don't plan on passing emissions w/o a cat. and yea, if you get caught...be prepared to pay out your ass for fines from the epa.
Old Jan 13, 2006 | 11:16 AM
except I am in Canada and we don't have the epa up here and we let major criminals go so not having a cat installed means only putting it back on and get it inspected. And then pull it out again
Old Jan 13, 2006 | 11:22 AM
pclear9061's Avatar
i would reccomend putting a high flow cat on b/c it will sound better than w/o a cat and its just better over all for everything. BUT if you dont want to have a cat then go and get an O2 simmulator and put that in .......... itll work but i dont reccomend doing it ........ i would rather have a high flow than nothing, but thats just me.
Old Jan 13, 2006 | 11:23 AM
GSoccer24's Avatar
i recommend high flow.
Old Jan 13, 2006 | 11:53 AM
DreamZ's Avatar
^^^^^ What they said.. I would go high flow
Old Jan 13, 2006 | 01:31 PM
GSoccer24's Avatar
i had them on my Z...no rasp, no CEL, and still passed emissions even when combined with headers and a full custom 3" cat-back
Old Jan 13, 2006 | 01:51 PM
the exhaust shop I went to said that our cat is already a high flow and he sees no reason to change it as it is already a 3 inch cat. so for now I will keep the cat in and see once I do my engine in March wether I want to yank it out a see what happens.
Thanks for all the fed back guys.
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
