Causes of random cylinder misfire
Old Jan 12, 2012 | 09:22 PM
2006g85sslobalt's Avatar
I chased my misfire for a year before I gave in and actually took it to a mechanic.turns out I had four wires that had rubbed raw somewhere.they were sending a seriously screwed signal and thus causing misfire.
Old Jan 12, 2012 | 09:38 PM
mrbelvedere's Avatar
the only time i had any misfire problems and a **** idle was due to the tune as for plugs ngk stock number 4644 that is one step colder copper core plug then the stock ngk that came in these engines which is a copper coree plug also
Old Jan 12, 2012 | 09:44 PM
05Slowline's Avatar
Originally Posted by mexi_loco
usually there's a vacuum leak which can cause random misfires. Bigger injectors can also help it out....although I would check all of your hoses and listen carefully to everywhere there's a gasket (s/c to intake mani, intake mani to block, throttle body, etc.)
this, intake side leak or bad plugs, coils, etc
Old Jan 13, 2012 | 12:37 AM
insylem's Avatar
Originally Posted by drumrush
im about to switch to 42's. on a 3.0 pulley theres no way i could even come close to maxing them out, i think 60's are overkill for my setup
I recently upgraded FROM 42s to 60s,
I still have my 42s if you want em.
Old Jan 13, 2012 | 12:44 AM
drumrush's Avatar
I just talked to a follow 2.2 on a 3.065 pulley who has 42's, and they are running at 96% duty. Ill stick with my 60's to be safe
Old Jan 13, 2012 | 12:48 AM
mexi_loco's Avatar
honestly bro, think about the code for a second: p0300: random misfire...if it was an injector issue, don't you think it would've given you a specific cylinder where the misfire was occurring? Here's my advice: pull the spark plugs and get out a spark plug chart. Spark Plugs are a great tool for diagnosing random misfiring b/c it can help you narrow down the problem from fuel, air, or spark issues. Obviously, we can rule out compression b/c your car is fine. So checking the spark plugs for all the tell-tale signs will help track it down.
Old Jan 13, 2012 | 01:13 AM
drumrush's Avatar
That's true, but I have less than a thousand miles on my plugs, so they will probably be new looking
Old Jan 13, 2012 | 07:35 AM
05Slowline's Avatar
lol needs a new tuner
Old Jan 13, 2012 | 09:53 AM
mexi_loco's Avatar
i had less than 1000 miles on my car when it had ottp's stage kit (2.8, 60's, blah blah), and when I pulled the plugs on it I could tell right away that I had a rich condition in my car. Those plugs smelled like they had been bathing in fuel.
Old Jan 13, 2012 | 11:24 AM
insylem's Avatar
Random Misfire Code can also be caused by a faulty / failing crank position sensor.
Old Jan 18, 2012 | 09:19 AM
  #36
kissmy05ss's Avatar
I have this problem under deceleration. Yes I have 60's, 2.7, bkr7e copper plugs, trifecta tune.
Old Feb 1, 2013 | 10:42 PM
  #37
kissmy05ss's Avatar
Anyone still having this problem with nothing obvious to point to, should do a Crankshaft position (CKP) variation learn. This solved my CEL and idle issues. Even feels like the car picked up a little.
turbochargedss2012
Sep 20, 2023 12:17 PM
717ssbalt
Oct 2, 2015 04:01 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
jmelton327
Sep 26, 2015 10:04 PM
