Cel P0172
ya dealerworld just says that its due to clogged injectors usually relating to a running lean condition but all gm will do is run an injector cleaner through your fuel line. so save yourself hassle and go and buy an injector cleaner. also did you just put an intake on your car. those have a tendancy to throw that code as well.
He's getting a p0172 which is a RICH condition......
didn't know that the ecm has a code for an aftermarket intake. but considering adding an aftermarket intake that may possibly have a leak in it will usually throw this code as the vehicle is tricked into thinking its running lean when its actually not thus causing the code to be thrown.
this is what the gm service information website says in regards to the CEL P0172
#03-06-04-030F: Various Driveability Symptoms Due to Clogged Fuel Injectors, MIL/SES DTCs P0171, P0172, P0174, P0300, P1174, P1175 (Clean Fuel Injectors and/or Perform Injector Test With AFIT - CH-47976) - (Dec 10, 2007)
Subject: Various Driveability Symptoms Due to Clogged Fuel Injectors, MIL/SES DTCs P0171, P0172, P0174, P0300, P1174, P1175 (Clean Fuel Injectors and/or Perform Injector Test With AFIT - CH-47976)
Models: 2000-2008 GM Passenger Cars and Light Duty Trucks (Including Saturn)
2003-2008 HUMMER H2
2006-2008 HUMMER H3
2005-2008 Saab 9-7X
with 2.0L, 2.2L, 2.4L, 2.8L, 3.1L, 3.4L, 3.5L, 3.8L, 3.9L, 4.2L, 4.3L, 4.8L, 5.3L, 6.0L, 6.2L or 8.1L Engine (VINs X, F, D, 4, 5, T, 8, J, E, H, L, 6, K, 1, 2, R, W, S, X, V, T, M, N, U, H, Y, 8, G -- RPOs LNF, L61, LN2, L43, LD9, LK5, LG8, LA1, LX5, LX9, LZ4, LZE, L52, L36, L67, L26, LZ9, LZ8, LGD, LL8, LU3, LR4, LM7, LH6, LQ9, LQ4, LS2, L76, L92, L18)
and MULTECŽ 2 Fuel Injectors
This bulletin is being revised to update the model year to 2008. Please discard Corporate Bulletin Number 03-06-04-030E (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment on any of the following various driveability symptoms:
• Extended Crank Time
• Hard to Start
• MIL/SES Illuminated with DTCs
• Hesitation
• Lack of Power
• Surge or Chuggle
• Rough Idle
• Light or Intermittent Misfire
Cause
Due to various factors, the fuel injectors may become restricted. Extensive testing has demonstrated that fuel related issues are the cause of clogged injectors. At this point, no specific fuel, fuel constituent, or engine condition has been identified as causing the restriction. The restriction causes the engine to operate at a lean air fuel ratio. This may either trigger the MIL to illuminate or the engine to develop various driveability symptoms.
Correction
Fuel injector restrictions, deposits can be cleaned on the vehicle using the following procedure. Under NO circumstances should this procedure be modified, changed or shortened. As a long term solution, and to prevent reoccurrence, customers should be encouraged to use Top Tier Detergent Gasoline . For further information on Top Tier detergent gasoline and fuel retailers, please refer to the following Corporate Bulletin Numbers:
2003-2008 HUMMER H2
2006-2008 HUMMER H3
2005-2008 Saab 9-7X
Condition
• Hard to Start
• Hesitation
• Lack of Power
• Surge or Chuggle
• Rough Idle
Cause
Correction
yea, I've done many cleanings on the injectors.....replaced leaking injectors and all.
However, he's got aftermarket 60 lb. injectors he just put in..soooo.....
haha it's all good.
just don't want the kid taking his intake off and thining his problem will be solved lol
Last edited by Sunburst_SS; May 27, 2008 at 11:11 PM. Reason: Automerged Doublepost
haha it's all good.
haha it's all good.
probably a MAF performance code, MAP code, along with a few others.....lean, rich...........but I doubt I'll throw an "intake" code
Last edited by Sunburst_SS; May 27, 2008 at 11:14 PM. Reason: Automerged Doublepost
just sayin....don't want some kid gettin the code and going WTF I have a stock intake hah
besides, most the time if you have a leak between the MAF and throttle body you will get a p0171 for a lean condition...since there is unmetered air entering the motor
i know but i said if he has a aftermarket intake plus i didnt want to sound like the code scanner because when i go get a code check and i see the causes it leave me more confused. so i just say intake !
ya either way if you are stock and you get this code as i have and my brother while being stock. you just need to run a fuel line/injector cleaner in your tank and it will clear it up. i have yet to have it come back my LT fuel trim is at 0% which is as perfect as you can get it. now my brother on the other hand was at 19% and ended up having his injectors replaced according to a bulletin that is out for them.
