Cel P0172
Old May 27, 2008 | 10:58 PM
cobaltz51r's Avatar
Cel P0172
any 1 kno this code
Old May 27, 2008 | 10:59 PM
outtamymind's Avatar
yup sure do know it. quite common actually
Old May 27, 2008 | 11:00 PM
XM15's Avatar
That means you are running rich.
Old May 27, 2008 | 11:02 PM
ya dealerworld just says that its due to clogged injectors usually relating to a running lean condition but all gm will do is run an injector cleaner through your fuel line. so save yourself hassle and go and buy an injector cleaner. also did you just put an intake on your car. those have a tendancy to throw that code as well.
Old May 27, 2008 | 11:03 PM
Darkmanx's Avatar
Its actually a code for aftermarket intakes , if you have one see if it came apart.
Old May 27, 2008 | 11:04 PM
Sunburst_SS's Avatar
ummmm, you're thininkg of p0171...which is a LEAN code
He's getting a p0172 which is a RICH condition......
Old May 27, 2008 | 11:05 PM
cobaltz51r's Avatar
no i just put in 60 lb injectors and ngk plugs 2 step colder and when i brought it down to get tuned he couldnt fully tune it yet so he adjusted it so it was driveable but that came up ty on the info
didn't know that the ecm has a code for an aftermarket intake. but considering adding an aftermarket intake that may possibly have a leak in it will usually throw this code as the vehicle is tricked into thinking its running lean when its actually not thus causing the code to be thrown.
Old May 27, 2008 | 11:07 PM
it's not a code for an intake! And there is no code "for" aftermarket intakes
Probalby a shitty tune for the car......
Old May 27, 2008 | 11:08 PM
this is what the gm service information website says in regards to the CEL P0172
#03-06-04-030F: Various Driveability Symptoms Due to Clogged Fuel Injectors, MIL/SES DTCs P0171, P0172, P0174, P0300, P1174, P1175 (Clean Fuel Injectors and/or Perform Injector Test With AFIT - CH-47976) - (Dec 10, 2007)
Subject: Various Driveability Symptoms Due to Clogged Fuel Injectors, MIL/SES DTCs P0171, P0172, P0174, P0300, P1174, P1175 (Clean Fuel Injectors and/or Perform Injector Test With AFIT - CH-47976)
Models: 2000-2008 GM Passenger Cars and Light Duty Trucks (Including Saturn)
2003-2008 HUMMER H2
2006-2008 HUMMER H3
2005-2008 Saab 9-7X
with 2.0L, 2.2L, 2.4L, 2.8L, 3.1L, 3.4L, 3.5L, 3.8L, 3.9L, 4.2L, 4.3L, 4.8L, 5.3L, 6.0L, 6.2L or 8.1L Engine (VINs X, F, D, 4, 5, T, 8, J, E, H, L, 6, K, 1, 2, R, W, S, X, V, T, M, N, U, H, Y, 8, G -- RPOs LNF, L61, LN2, L43, LD9, LK5, LG8, LA1, LX5, LX9, LZ4, LZE, L52, L36, L67, L26, LZ9, LZ8, LGD, LL8, LU3, LR4, LM7, LH6, LQ9, LQ4, LS2, L76, L92, L18)
and MULTECŽ 2 Fuel Injectors
This bulletin is being revised to update the model year to 2008. Please discard Corporate Bulletin Number 03-06-04-030E (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment on any of the following various driveability symptoms:
• Extended Crank Time
• Hard to Start
• MIL/SES Illuminated with DTCs
• Hesitation
• Lack of Power
• Surge or Chuggle
• Rough Idle
• Light or Intermittent Misfire
Cause
Due to various factors, the fuel injectors may become restricted. Extensive testing has demonstrated that fuel related issues are the cause of clogged injectors. At this point, no specific fuel, fuel constituent, or engine condition has been identified as causing the restriction. The restriction causes the engine to operate at a lean air fuel ratio. This may either trigger the MIL to illuminate or the engine to develop various driveability symptoms.
Correction
Fuel injector restrictions, deposits can be cleaned on the vehicle using the following procedure. Under NO circumstances should this procedure be modified, changed or shortened. As a long term solution, and to prevent reoccurrence, customers should be encouraged to use Top Tier Detergent Gasoline . For further information on Top Tier detergent gasoline and fuel retailers, please refer to the following Corporate Bulletin Numbers:
Old May 27, 2008 | 11:09 PM
cobaltz51r's Avatar
probly any 1 kno of a good place to get tuned in the new york fishkill area
and sorry i should have been more clear i was being sarcastic when i was talking about the intake code
Old May 27, 2008 | 11:11 PM
yea, I've done many cleanings on the injectors.....replaced leaking injectors and all.
However, he's got aftermarket 60 lb. injectors he just put in..soooo.....
haha it's all good.
just don't want the kid taking his intake off and thining his problem will be solved lol
Last edited by Sunburst_SS; May 27, 2008 at 11:11 PM. Reason: Automerged Doublepost
Old May 27, 2008 | 11:12 PM
Darkmanx's Avatar
go disconnect your intake where the tubes meet and tell me what code you throw.
Old May 27, 2008 | 11:13 PM
haha it's all good.
no worries. ya had i read that he had done a few modifications to his car as well as a tune i would have also informed him to go and get retuned as that would the most likely cause.
Old May 27, 2008 | 11:14 PM
probably a MAF performance code, MAP code, along with a few others.....lean, rich...........but I doubt I'll throw an "intake" code
Last edited by Sunburst_SS; May 27, 2008 at 11:14 PM. Reason: Automerged Doublepost
Old May 27, 2008 | 11:15 PM
Darkmanx's Avatar
******* ass you know what i ment. Its a code releated to the intake being disconnected.
Old May 27, 2008 | 11:19 PM
just sayin....don't want some kid gettin the code and going WTF I have a stock intake hah
besides, most the time if you have a leak between the MAF and throttle body you will get a p0171 for a lean condition...since there is unmetered air entering the motor
Old May 27, 2008 | 11:22 PM
Darkmanx's Avatar
i know but i said if he has a aftermarket intake plus i didnt want to sound like the code scanner because when i go get a code check and i see the causes it leave me more confused. so i just say intake !
Old May 27, 2008 | 11:24 PM
ya either way if you are stock and you get this code as i have and my brother while being stock. you just need to run a fuel line/injector cleaner in your tank and it will clear it up. i have yet to have it come back my LT fuel trim is at 0% which is as perfect as you can get it. now my brother on the other hand was at 19% and ended up having his injectors replaced according to a bulletin that is out for them.
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
