Changing Pulley
Old Apr 17, 2008 | 06:23 PM
fgibney89's Avatar
Question Changing Pulley
If i was gonna change the pulley should i buy the pulley puller or is that just something to make them more money? JW cause some people are telling me it should slide off.
Old Apr 17, 2008 | 06:28 PM
Hockeyman's Avatar
The stock pulley is tricky to get off, a press or puller is needed. You can't just slap on a smaller pulley either, gotta have a lot of supporting mods first.
Old Apr 18, 2008 | 12:31 AM
nherbst454's Avatar
If you've already got the stage 2 kit installed, then the pulley just needs to be unbolted, then bolt on the new pulley. If you've still got the stock press on pulley, then you will need a puller/install tool (I make that as well as pulleys) to pull the stock pulley off then press the new pulley hub on.
Here's a link to the puller...
http://www.smoothflowpulleys.com/Pulley_Puller.html
Nate
Old Apr 18, 2008 | 08:00 AM
EmperorJJ1's Avatar
damn swapping pullies is gonna be harder then i thought
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
