Check engine light
Old Apr 2, 2011 | 12:54 PM
RedSuperSport's Avatar
Check engine light
so my cel came on bout a month ago and hooked it up to my uncles computer and said it was running system to lean bank 1. Im away at school so i didnt have time to bring it to the deal cuz its still under warranty so i finally get up there yesterday and after an hour there the guy comes in and says the oil cap was missing(either came off driving or the last time i brought it in they didnt put it back) so they say that was the problem and i leave. half mile down the road it comes back on so i turn around and bring it back in and i sit fr another 3 hours and they say theres some timeing issue and they dont why its running lean yet so i had to leave and i made an appointment in another 2 weeks when im back from school. Si when i leave the dealer the cel light is still on and about 4 hours later im drinving home from my girls house and i realize the ****** thing went off........ the SS is killing me right now idk if its fucked up or not? anybody else ever have an issue? should i bring it back in 2 weeks cuz they told me theres some timing issue? someone give some advise. anything would be appreciated!
Old Apr 2, 2011 | 01:01 PM
insylem's Avatar
The CEL will go off on some codes, if the condition is resolved. Or if the light burns out. Does it still come on right when you start it, then go off? Alot of times dealership guys are idiots. Aperently they have no clue whats going on with your car. Take it to Autozone, have them scan the codes, they may find a P0171 (System Too Lean Bank 1) Have them delete it and see if it comes back.
Its possible you had some bad gas, and the fuel system had to add more fuel to compensate, then you got some good gas and it corrected itself.
BTW: Check for leaks in your hoses and intake ducts.
Old Apr 2, 2011 | 01:14 PM
i had my uncle delete it when it first came on and then came back on not to long after so its just being a pain in the effing ass man and i want to put my intake in soon but i dot want to bring it in with the intake in and try and **** me cuz the intake is in
Old Apr 2, 2011 | 01:27 PM
insylem's Avatar
Ya check for air leaks under the hood.
If its still under warranty, make them
give you a rental, and give them your
car and tell them not to give it back
till its fixed! The longer they have it
the longer you have the rental so it'll
behoove them to fix it quick.
Old Apr 2, 2011 | 01:44 PM
chevysssc's Avatar
if its under warrenty make them fix it or they will say neglect
and call gm if problem continues
Old Apr 2, 2011 | 02:21 PM
yea i agree 100% guys i jus thought it was wierd that it was on and said there was another underlying problem then it went off a few hours later so its not likt the cleared it and came back on ... it was on and went off lol
Old Apr 3, 2011 | 12:01 AM
insylem's Avatar
Maybe they fixed it and forgot to reset it.
Go to Autozone or Advanced and have them run a code check,
If your good your good
Old Apr 3, 2011 | 06:03 PM
yea i think ill do that but i may just take it in and leave it with them and make them make sure its all good u know just to be sure... thanks for the input guys
Old Apr 4, 2011 | 08:07 PM
mattyk33's Avatar
the check engine light when on after a cold air intake was installed. could this be just because the difference flow of air by the aftermarket part rather then stock? any ideas on how to get it off
Old Apr 4, 2011 | 11:57 PM
insylem's Avatar
If your CEL came on after you installed a new intake
Best way to get it to go off, is get your PCM retuned for
the intake.
Old Apr 5, 2011 | 10:57 AM
i havent installed the intake yet... i was going to last weekend if the fixed that car and they didnt but the dam thing went off by itself...so i was debating to put in cuz it went off but i didnt cuz im going to bring it back just in case there something wrong still and i dont want them to try and say we arent gonna fixe it cuz u put an aftermarket part in it... im on spring break in 2 weeks so ill put it in then =) i need to hear my supercharger asap
Old Apr 5, 2011 | 07:08 PM
mattyk33's Avatar
so could i just go to a normal garage for that and how much does it usually run
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
