Check engine lite. NO HIGH END POWER.
Old Nov 24, 2008 | 08:14 PM
FrankTheTank's Avatar
So i'm driving home from work yesterday and check engine light comes on. My car was running a little rough earlier this month. I had an exhaust leak due to shitty reused stock gasket when i put that hahn cat back on. Well replaced that and car was running fine untill yesterday. So i pull over and check the oil and coolant levels. They where fine. idle seemed to be ok. so i get on it and at about 5k there's no power. the s/c is screaming but i'm not going anywhere. so i get almost home and it goes into limp mode. I also noticed the boost is running high as f'k lately 20 psi. Is my cat cogged? I'm asuming i have to put stock cat back and engine mount on if i expect to get covered by warrenty. any suggestions. at idle the s/c also sounds like it's chattering. should i find an origional air filter/box. for warrenty reasons i have a the cone filter air box mod. . also what spark plugs does the dealer use for stage 2.
Edit ahahahha lol. ooops. Check engine. *LIGHT
Old Nov 24, 2008 | 09:30 PM
restonSS's Avatar
yeah i would put the stock motor mount back on. intake they could call you on for the check engine light. some dealerships say they cant accurately diagnose something if there is a different intake on. exhaust you should be fine. they can say anything.
Old Nov 25, 2008 | 02:40 AM
rukkee's Avatar
I would put the stock intake on for sure , thats a biggie for dealers to blame any rich lean stuff on . They could say it screwed with the maf and caused the A/F to change clogging the cat lol. No **** i've heard that said by a tech. Seeing as you have a hahn CB , a after market DP would be a nice addition to the exhaust system. The stock downpipe is the most restrictive part of the whole system, and it definitely sounds like its clogged.
Oh the dealership uses the stock plugs for stage 2 , NGK R PFR6T-10G
Old Nov 25, 2008 | 09:59 PM
Thanks for the reply's guys. Does aftermarket cat back void warrenty? I'm assuming it does. Now i need to find a stock air filter/box. thanks for your help.
Old Nov 27, 2008 | 03:15 AM
bumpity bump. HAPPY THANKSGIVING!
Old Nov 27, 2008 | 03:20 AM
CobaltSS 16's Avatar
sounds like a clogged cat.
Old Nov 27, 2008 | 09:13 PM
well that's my guess. What's your thought on putting the stock exhaust back on before taking to dealer. I just tlaked to a friend of mine who was a mechanic for ford and he said they can't deny me for haveing a cat back seeing as how it's a bolt on.
Old Nov 28, 2008 | 01:15 AM
ehh, i would since the cat is in the exhaust system and they could end up blaming it on that, but technically it shouldn't effect anything. It's up to you.
Old Nov 29, 2008 | 09:07 PM
rukkee's Avatar
A CATBACK shouldnt mean anything to a dealer , it's away from anything that could fail . GM offers a catback so if theirs doesn't void a warranty either should any other brand. The only thing they could say is that the aftermarket exhaust was crushed or had a restriction that caused the cat to fail, highly unlikely thou.
Old Nov 29, 2008 | 09:10 PM
originaladrian's Avatar
wht code are u throwing? please tell me u checked before posting...
it astounds me the number of people who get CELs and dont check the code. its the first thing u should do and any tech is going to do
Old Nov 29, 2008 | 10:49 PM
tomst9's Avatar
Whats the code. If the code set has something to do with the exhaust, or intake they are probably not going to try to fix it under warranty, but thats up to them. Pull the code and go from there!!!
thanks
tom
Old Nov 30, 2008 | 03:10 AM
Well I wish i could say i checked the code before i posted. I don't have a scan tool, I'm currently out of town, and have been working and dealing with family and holiday stuff so haven't had the chance to make it to autozone to use theirs. I know It's like checking the fuses when you have an electrical problem. Again thanks for you comments and concerns.
I'm in Chi-town it's awesome here during christmas time.
Old Nov 30, 2008 | 02:57 PM
Dainslaif's Avatar
High boost + no top end power = bad cat. I guarantee it.
They can't refuse service for either the motor mount nor the catback since neither could possibly ruin the cat itself, but I'd get the code checked to make sure it's not an intake code before dropping it off (and you might as well change that back since it's only a 15 minute job).
Old Nov 30, 2008 | 07:31 PM
see the thing is i do not have my new intake on. Just the airbox mod at this point.
Old Dec 3, 2008 | 01:09 PM
Well i must say the service guys at my Chevrolet dealer are above any i've heard of. I got the codes checked [P0420 catalyst eff. below threshold (bank 1)] and [p0068 MAF/MAP sensor throttle position correlation.] So i go to the dealer. I was stuck on the thought that the cat was clogged thinking all that back pressure caused the maf/map code. so i take it in. The service rep says well do you have a stock air filter. Of course I give him the wrong answer. NO. so he talks to his manager and they come walking out. They say look. You need to replace the filter with stock filter. The k&n filters have a oil coating that screws up the maf sensor. So replace that too. Then we can pretend we didn't have this conversation. Otherwise not covered under warrenty. Problem is i do not have the stock airbox. It has been modded for the cone filter. The intake is stock but the airbox is hacked and I do not know where to find one. Unless i order it through the dealer. Which wouldn't bother me too much seeing as how good those guys treated me. Any suggestions.
P.S. I work midnights and haven't been to bed, sorry for the grammer and spelling. But hay that's not why we're here anyways. Right?
Old Dec 3, 2008 | 01:22 PM
ShortStack's Avatar
I have a k&n filter. and yes it is oiled, and it can dirty the maf, but it doesnt ruin it. Thats awesome though that they will replace it and all that jazz...
If you want the warrenty work, i may have my stock air filter a round...
Old Dec 3, 2008 | 02:17 PM
Yeah i really should post a wtb thread on here and see if i could pick one up in state. Shoot me a message if you have a price though. Thanks'
Frank
Old Dec 3, 2008 | 11:31 PM
rukkee's Avatar
If you cant find one let me know , i will lend you mine but i need it back just incase i run into the same situation. Let me know , i don't mind helping a fellow cobalter out .
Old Dec 4, 2008 | 12:08 AM
Well i believe you're right. They told me to replace the maf too, but i know you can clean it with electrical contact cleaner. Some cleaners like windex don't work because they leave a residue. a couple quick sprays from electrical contac cleaner allowing to dry between sprays. That's how i do it. I did it on my T-bird a couple times. They said as long as there's no oil on the maf and the stock air box is on they're replace the cat. If there is a problem there. I'm gonna try cleaning the maf and see if that fixes it.
Old Dec 4, 2008 | 02:23 PM
Dainslaif's Avatar
Just get some MAF sensor spray cleaner from Autozone. It's like 7 bucks for a can that'll last you forever.
Old Dec 7, 2008 | 09:56 PM
Thanks everyone. I ended up getting one from someone up here in Michigan.
Old Dec 8, 2008 | 09:36 AM
ShortStack's Avatar
what part of MI?
i got tons of fam up there.
Old Dec 9, 2008 | 01:03 AM
what part of MI?
Well i live in New Boston. It's by the Detroit West airport. DTW. off of I275
Jared Let me barrow his airbox. He's from Waterford. Which is about 40 miles north of here.
Old Dec 18, 2008 | 03:51 PM
OK guys guess what. They fixed it. what did they do? oh um took the fur ball out. lol. New Cat and also replaced my by pass actuator solenoid/valve. So she idles correctly and runs like a champ. Oh my gosh. The exhaust sounds so much better too. I love my Hahn cat back. That cat was restricting my exhaust so bad. Now I can't hear the s/c anymore with the stock airbox on. Thank you everyone for your help and concerns with car.
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
TurboTechRacing
Oct 27, 2015 07:58 AM
bucks121
Sep 12, 2015 07:39 PM
Fearedbynone
Sep 4, 2015 10:24 AM
