Check engine on my SS 2.0; mulitple codes
Old Apr 6, 2011 | 08:20 PM
OneSlowRedSS's Avatar
I am getting the following check engine codes:
P0069--map/barometric correlation
P0068--maf/map sensor throttle position correlation
P2228--barometric circuit low
Car was working great til up til now. I was driving along with cruise set at 60 when my car went into reduced power mode.
I pulled over & unplugged the sensor near the oil filter cap. I did an oil change 3 weeks ago and I was think maybe I some how disconnected it. Unplugged and replugged the connecter. Car started up but CEL was on. Drove it to work just fine. Get out off work at 5:30 and about half way home it did it again.
My mods include: GM stage II, Injen CAI, GMPP exhaust. Those items have been on for over 2+ years. I have about 104k on the car.
Any ideas on what might be going on or could point me in the right direction? Much rather not go the Stealership...
Thanks!!
Old Apr 6, 2011 | 09:21 PM
alleycat58's Avatar
Yeah it sounds like you pulled a wire loose that you shouldn't have.
Old Apr 6, 2011 | 09:32 PM
Leafydialupking's Avatar
I see the word barometric, which would relate that code in some way to the sensor on the top of the blower.
Old Apr 6, 2011 | 09:34 PM
alleycat58's Avatar
That's the one that usually gets disconnected (at least I disconnect it) when doing an oil change. Either way, check the connection and make sure it's tight.
Old Apr 6, 2011 | 09:36 PM
ecot3c inside's Avatar
surprised you didn't get engine power reduce! these are the codes that popped up for me when I got it, all my wires were good though. I just cleaned them up and re-did em'.
brandon04
Oct 21, 2015 07:04 AM
Sep 28, 2015 12:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
