Cleaning the LIM
Cleaning the LIM
Is it ok to remove all the senors from the intake, the laminova cores and o-rings/washers, and soak it in something like Purple Power to clean grease and oil off of it?
i took my cores out te washers off and the orings off and soaked EVERYTHING in a combination of dawn dish soap and some heavier duty cleaner in a utility sink in my garage overnight. then washed everything off really well and let it dry for 2-3 days. the cores hold water inbetween the grooves like no other.
also like nhanson said. when you reinstall the washers, put a little bit of new motor oil on the rubber orings when u install it to help and make sure they "seat"
