Cleaning the LIM
Old Jul 1, 2012 | 07:57 PM
08baltls's Avatar
Cleaning the LIM
Is it ok to remove all the senors from the intake, the laminova cores and o-rings/washers, and soak it in something like Purple Power to clean grease and oil off of it?
Old Jul 1, 2012 | 07:59 PM
nhanson's Avatar
Yes. Be extra careful with the cores.
Put some oil on the core orings when you reinstall.
Old Jul 1, 2012 | 08:01 PM
08baltls's Avatar
Just regular motor oil?
Old Jul 1, 2012 | 08:02 PM
AzraelRaezier's Avatar
This,
i took my cores out te washers off and the orings off and soaked EVERYTHING in a combination of dawn dish soap and some heavier duty cleaner in a utility sink in my garage overnight. then washed everything off really well and let it dry for 2-3 days. the cores hold water inbetween the grooves like no other.
also like nhanson said. when you reinstall the washers, put a little bit of new motor oil on the rubber orings when u install it to help and make sure they "seat"
Old Jul 1, 2012 | 08:03 PM
anything kind of motor oil will work. i used a little bit out of a new bottle of oil we use to mix with gasoline for our weed wacker and edger
Old Jul 1, 2012 | 08:06 PM
nhanson's Avatar
Yes regular motor oil.
If you wanted to be really special you could get some water proof grease.
I didnt oil the end plate gasket, just make sure it seats in the groove.
Old Jul 2, 2012 | 01:24 AM
i oiled it for ***** n giggles. never had any issues.
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
grampss
Sep 27, 2015 08:51 PM
