clutch help
Old Sep 19, 2010 | 09:50 AM
usmc6212's Avatar
clutch help
I did my clutch and its fully installed. I am trying to bleed the clutch and no matter what I can not get any peddle pressure. I did for a while but as soon as I start the car the pressure goes away. I need help or else i am going to have to take it to the stealership and let them fix it. Its a zzp stage 4 clutch upgraded throwout bearing fidaza flywheel and axles
Old Sep 21, 2010 | 11:58 AM
DVSk8er's Avatar
check to make sure there are no leaks anywhere. mainly the tob inside the trans. you would see brake fluid dripping out of the bottom. and make sure the distribution block on top of the trans where the bleeder is is properly clicked into place.
Old Jan 17, 2012 | 10:11 PM
Rreyn06's Avatar
I changed my clutch on my cobalt and for some reason my distribution block wont clip in. I bought a new distribution block with the clips in hopes for it being able to click properly but it would go all the way down and not click. Any help on that?
Old Jan 17, 2012 | 10:14 PM
Chevycobaltss3's Avatar
For it to clip down the clips need to be aligned along with the bolts to connectors through the block. It should go through fine. Just mocmve it around a bit
Old Jan 17, 2012 | 10:20 PM
Powell Race Parts's Avatar
you may have a swollen seal on the clutch pipe if you did not replace it and it will be very difficult to install , requires a lot of pressure to engage the hairclip . Good luck.
Old Jan 17, 2012 | 10:23 PM
u must remove the clip to install the block.
Check post 3 for the last question.
Nm you found it
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
