Clutch problems
Old Oct 23, 2006 | 09:50 PM
SSteveSC's Avatar
Clutch problems
So has anyone figured out the problems with the clutch yet.. my brand new 2007 has clutch slippage..
Correct me if im wrong, when u go WOT to 6000 rpm, then shift, and it seems like the revs float around 4500-5000 rpms for like 2 seconds, then it catches and starts to go up, is that clutch slippage or just spinning the tires?
Old Oct 23, 2006 | 10:05 PM
SoloZ/SS's Avatar
How many kilometers do you have on your car?
JAESS's Avatar
U should smell the clutch if its slipping. U should also beable to tell if your tires are spinning.
Joe
Old Oct 23, 2006 | 10:10 PM
campo165's Avatar
sounds like clutch slip. my car personally almost instantly drops to right under 4k and burns some tire...grips like a champ
Old Oct 23, 2006 | 10:13 PM
Boosted_SS's Avatar
check out this thread out it may offer some insite...
https://www.cobaltss.net/forums/drivetrain-79/how-make-your-clutch-stop-slipping-find-out-inside-36130/
Old Oct 23, 2006 | 10:23 PM
SSteveSC's Avatar
i got 2200 km on it
the first time i did it, it smelt bad,
tonight i tried it, and it smelt, but not for as long
Old Oct 24, 2006 | 07:31 PM
SSteveSC's Avatar
ok tonight, i opened er up again.. and holy **** did it ever slip.. 1-2 slipped soooooooo bad that it pretty much seemed like 2nd gear wasnt there, kinda hard to explain..
but anyways, the aftermath was a lot of stink, and i tried buddies theory, it didnt work for me.. been driving shifting around 3k all day, and didnt do the trick
Old Oct 24, 2006 | 07:41 PM
Boosted_SS's Avatar
give it a couple days shifting at 3K
Old Oct 24, 2006 | 08:56 PM
eastcoastz's Avatar
Funny thing about my car was at first I had this slip problem, but the more power I started to make with modds it completely went away.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
