Clutch slip test. I have new info!
LSX RWD S/C conversion
Originally Posted by Badmunky
Ok guys Im at the dealre adn have some info for you.
1st. The clutch master cylinder and the lines are all the same parts as the 2.2L and 2.4L cars.
So if the problem was in these parts all cobalt should be having the problem not just the SS S/C.
2nd. The SS S/C gets a diferant slave cylinder then the other cars do. And Im thinking the problem is right here.
3rd The clutch line is 2 pices adn a T fiting thing with a bleader in it.
4th. There is some kind of thin spacer the gose in betwean the trans and the motor.
If you changed your clutch adn did not put this back in the tec ses it could be a problem.
There changing my master cylinder right now.
Im not sure how long this will take but they have had the car for about 30 min now and its looking like I will not get it back for about another 1-1.5 hours.
Later
Later
The only time my clutch slips is the 1st-2nd shift. As you said it is not consistant. I was racing some hot chick in a TSI last night. We went from a few lights and every time I could floor first get to redline and shift and it would grip instantly. Usually a pretty hard thud, and I even chirped shifting into second. Bottom line is I whooped her ass every time we went, but no slippage what so ever. Now a few nights ago I was showing my friend my car and went from a light and got to redline shifted and it grabbed but it took a while for the engine RPMS to catch to the clutch. (I assume this is slipage) Basically after a shift it winds down before starting to wind up. As soon as you let go of the gas it will catch and your good to go, but this is annoying sometimes. Its not consistant and really makes me wonder.
Originally Posted by SSCobalt~SSZ24
they did my master cylinder and it did nothing i think most of the gm mechanics are lost as to what is the problem
Mine has actually slipped from 2nd to 3rd but only at the racetrack did it once or twice has not done it since, I have 32000km on my car and everyday driving, the clutch does not slip nor does it slip when i hammer it in first....tires spin and the front end hops alot so i dont do it often but i was trying to fiqure out if i had some of these issues...so far nothing really...!
P.S This is my first Manual Car, Knew how to drive one (was an Emissions Tester for Two years), but never really drove one on the road only on dynos until this one... So my experience is limited...
Yes, it think it's the slave cylinder also. I will explain my issues. I have no slippage from 1st to 2nd, then I will be in WOT and feel very little power as the RPMs rise in 2nd. Then suddenly around 5000 RPM, it's like being rear-ended! I will get out of the car and smell the tell tale burn! This does not seem to happen back to back either. Once I get the slam and burn it will work fine for the rest of the night! This doesn't happen everytime either. At first I thought my boost by-pass valve was sticking open, until I smelled the burn. The 2nd thing I am noticing. Everyday I go to start my car for the first time, as I engage the clutch before turning the key, I hear a faint crunching sound. This only happens after sitting for a lenghtly time. 8 hours, plus! It would be nice to get more input from GM to what the problem is but they seem to be in denial, go figure!
Later
Later
#36
Master cylinder got replaced and it helped the situation but the clutch is still slipping. Looks like Im going to have to see if I can get the slave cylinder replaced. Either way this looks like its evertually going to be an expensive fix. Don't know about this year looking more like next spring when I'll be fixing this problem.
Currently it only slipped 1 time in about 20-30 2-3 shifts. If I alter my shifting a lil bit I can get it to not slip but it means going a lil slower in races.
#37
so when they replaced the master cylinder, they bled the mc...but did they bleed at the bleeder fitting down the line? this is a huge problems with 2zz corolla XRS' with the same exact symptoms.... seen many swapped at 12-15k
#40
Originally Posted by artawesome
how do you know when your clutch is slipping? how does it feel? just wondering because i ve nevered experienced it before (or if i had, i couldnt tell?)
#41
Originally Posted by p7x
U'll know it when the rpms go up and the car isnt going any faster. Or if the rpm needle goes one way and the speedo needle goes the other way.
#42
so its like reving the engine in neutral or with the clutch in.
#43
ya kinda. Ok, imagine driving down the highway in whatever gear and you punch it.....and the rpms fly up but the car doesnt accelerate.
#44
Ok I have some new info guys. It seams that the tecs at my dealer think that the slave cylinder is holding a vary small amount of air in it even after they bleed it several times.
And that with fast shifting the fluid is airating and slowing the clutch engagement and thats making it slip.
They are working on a fix for me and I have to take the car in as soon as I get home.
They are going to do some testing and let me and GM know what they find and then we might get the problem fixed.
Later
Later
#45
1 Post
Ok I have some new info guys. It seams that the tecs at my dealer think that the slave cylinder is holing a vary small amount of air in it even after they bleed it several times.
And that with fast shiftin the fluid is airating and slowing the clutch engagement and thats making it slip.
Later
Later
#47
Originally Posted by codyss
Anyone who thinks the Cobalt clutch hyraulics suck should go drive a 1998-1999 F-Body.
GM put a screen in the hose that goes to the slave cylinder so that the fluid would have some restriction to prevent driveline shock. The clutch is normal until a nice fast shift, then it gets really squishy since it foams the fluid then it engages in different spots or gets stuck to the floor!
I have a feelling that the hydraulics on the SS/SC are either to weak or there is a similar restriction in the lines.
Hope GM will admit fault on this one. Most unlikely though. They usually will tell you: "Well its your fault for racing it in the first place."
#48
