Cobalt stage 2 Broken MT-2 Tool
Old Oct 11, 2007 | 01:34 PM
cobaltz51r's Avatar
Hey has any 1 had the problem of trying to change the pulley on the stage 2 from the 3" stage 2 to a 2.8" pulley. my bolts are so tight that i broke the MT-2 tool that comes with the kit and now im **** out of luck. GM dealers dont have this tool at there shop nor they said they cant get the tool seperatly. i would have to buy the whole kit over again just to get the tool. has any 1 had this problem and if so how can i get my bolts off witch are suposed to be 18ft lbs of torque and they are not. how can i get them off now with out ruining my whole supercharger.
Old Oct 11, 2007 | 01:35 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Isnt it just a TORX bit?
Old Oct 11, 2007 | 01:38 PM
xravenwingsx's Avatar
nope--it's an offset-type bit--similar to what we use on our F-16's. They suck where I work too because they're always breaking and stripping out screws when you try to remove a jet panel. AN-style--I think some people are dremeling the bolts off, but I wouldn't recommend doing that until you get some replacement Hex bolts from Nate. I think whoever landed that government and GM contract should be shot. The design sucks.
cobaltz51r--don't forget to add some cooling mods eventually, the smaller pulley is going to create more heat--bad for performance and reliability. Cobra heat exhanger and Royal Purple 'Purple Ice' coolant additive should work wonders.
Old Oct 11, 2007 | 02:05 PM
cobaltz51r's Avatar
yea im on the waiting list from WWW.Cobalt-Addiction.com for that heat exchanger but what should i do to get those bolts OFF tho they really do suck and GM wont do anything about it They say they cant even get that tool for there own shop. to take it off for me when i brought it to them you kno
Old Nov 17, 2007 | 12:12 AM
trent_ky's Avatar
**** i need one of those tools anyone know where i can get one??
Old Nov 17, 2007 | 01:53 AM
nherbst454's Avatar
What you may have to do is use a dremel cut-off tool to grind a slot in the bolt head, then use a large screw driver to get them out. Another option is drilling the head off, removing the pulley, then using a vise-grips on the studs which are left.
Nate
Sean Cummings
Sep 11, 2015 09:35 PM
Bluelightning
Sep 8, 2015 05:18 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
CobaltSS 16
Sep 6, 2015 02:04 PM
NoBalt123
Sep 4, 2015 07:10 AM
