Code P2176 And P2135
Old Sep 12, 2022 | 04:27 PM
GGMisfitt's Avatar
Exclamation Code P2176 And P2135
I have a 2007 Cobalt SS, I started with only a code for P2135 which is TPS Sensor Voltage Correlation DTC. I did some research and I just replaced the entire throttle body assembly. Drove fine for a day and a half then stopped at a gas station turn on car it went into limp mode with 2 codes the P2176 ( Throttle actuator control system - Idle position not learned ) and P2135. I dont know where to start looking for the problem. I have people telling me i should re flash my ECU or check for a problem with the wiring, or the Pedal position sensor could be bad. If anyone has had this problem before where should I start? This is my daily so its pretty hard getting to work because i cant drive it.
Old Apr 13, 2023 | 05:21 PM
Coom Lord's Avatar
I’m having similar issues, we’re you able to find a fix?
jaiidutch
Sep 10, 2020 12:46 PM
terry11
Feb 17, 2013 12:41 PM
ericgt79
Jan 18, 2013 02:19 PM
redcobalt07
Jun 11, 2011 09:03 AM
Wadsy`s LS
Mar 4, 2010 11:27 AM
