P0221 code
Old Jan 17, 2013 | 10:44 AM
ericgt79's Avatar
Angry P0221 code
OK so i took my car to Oriellys and read the code im getting right now its:
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
when i drive the car its fine then all of a sudden i get "eng power reduced" and i have no throttle response PERIOD. this happend to me on the damn highway! so i turn the car off and back on and it works fine for a few mins then boom, again.
I replaced the evap solenoid after research on here and it ran better for a few mins then boom no throttle again. so i reset the car for damn near 25 mins started it let it run 10-15 then drove and not 2 mins into the drive it did it again.
any ideas?
Old Jan 17, 2013 | 11:05 AM
prevsrt4owner's Avatar
New throttle body?!
Old Jan 17, 2013 | 11:08 AM
ericgt79's Avatar
No
Old Jan 17, 2013 | 11:16 AM
ericgt79's Avatar
Maybe it's dirty and needs to be cleaned?
T-Man's Avatar
Gms1?
Old Jan 17, 2013 | 11:21 AM
ericgt79's Avatar
Trifecta
Old Jan 17, 2013 | 11:25 AM
Eric, from researching, it looks like the only fix is a new throttle body.
Old Jan 17, 2013 | 11:27 AM
68Vette's Avatar
The code book says: Throttle position, Sensor #2(redundant) range check poti voltage - Primary malfunction signal and criteria = sensor difference > 9(threshold value) specific units = %.
Secondary Parameters = battery voltage > 7 volts, continuous.
Old Jan 17, 2013 | 11:32 AM
ericgt79's Avatar
Will a simple cleaning fix that problem or do I need to just get a new one?
I can't find any how tos on cleaning
Old Jan 17, 2013 | 02:22 PM
68Vette's Avatar
I personally don't know a "quick fix" for that so replacing it may be the only alternative.
Old Jan 17, 2013 | 02:54 PM
This!
Old Jan 17, 2013 | 08:24 PM
10SSKY's Avatar
This is also happening to me. Does your ESC turn off too?
Old Jan 18, 2013 | 02:19 PM
Wangspeed's Avatar
You can't clean out the TB easily. Carb cleaner will kill it too. Did you spray something through the intake, like meth?
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
