codes
Old Jul 26, 2009 | 05:18 PM
mrbelvedere's Avatar
codes
hey got some codes some i know what they are but others i dont i know i need to clean the maf but would it set all the other codes
poo36
po135
po141
po300 misfire
p1182
poo68
p2228
besides cleaning the maf what else do i need to do
Old Jul 26, 2009 | 05:21 PM
REIGN SS's Avatar
Original Hayden Fanatic
Did you check the stickies?
https://www.cobaltss.net/forums/showthread.php?t=3480
https://www.cobaltss.net/forums/problems-service-maintenance-69/cobalt-dtc-thread-merged-12015/
Old Jul 26, 2009 | 05:29 PM
so what if the code peads pcm does that mean i have a bad pcm i did look in the stickies but dident see anything and thanbk you for the links
Old Jul 26, 2009 | 06:04 PM
Maven's Avatar
While cleaning the MAF cant hurt, none of those codes are actually directly MAF codes.
36,135,141 are all heated oxygen sensor codes. do you have a rear O2 sensor plugged in? is your EMISSIONS fuse blown now, or recently? Crush or damage any wires during an exhaust install?
Misfire is a misfire...
1182,68 are airflow codes, but not necessarily the MAF
2228 is a BARO code.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
