Cold Start Tap video
I have a 2004 saab 93 AERO which has the b207r engine which is the brother to thr jsj minus the turbo I have a weird cold start up tab that lasts only a minute smooths out never hear again for the rest of the day until the next day cant seems to find the issue seeing if any of you guys heard of or have the same problem
Saab tap - YouTube
thanks for looking
Saab tap - YouTube
thanks for looking
Time to break out the long screw driver and have a listen to your motor.
Place the flat blade on different places on the motor with the handle to your ear.
When you find the area with the problem you will hear it. It will help you track own the noise anyways..
Took it apart found that the balance chain tensioner was gutted the plunger was gone and the guide broken I couldn't find the replacement parts from saab so too a gamble and I ordered them for a cobalt ss and every thing was the same except the balance shaft gears (the ones on mw car was a little thicker) so I reused them other than that all timing componets where the same put it back together and fired it right up and now you can't even hear it run not even a vibration from the engine
roth
Sep 26, 2015 12:16 PM
