Cold Start Tap video
Old Jan 30, 2012 | 03:42 PM
AEROplane's Avatar
I have a 2004 saab 93 AERO which has the b207r engine which is the brother to thr jsj minus the turbo I have a weird cold start up tab that lasts only a minute smooths out never hear again for the rest of the day until the next day cant seems to find the issue seeing if any of you guys heard of or have the same problem
Saab tap - YouTube
thanks for looking
Old Jan 30, 2012 | 06:21 PM
Pepsi's Avatar
Sounds like spark. Did u check your coils and plugs?
Old Jan 30, 2012 | 06:36 PM
05Slowline's Avatar
Timing chain or turbo? Where's the noise seem to derive from?
Old Jan 30, 2012 | 07:48 PM
cavfiredesire's Avatar
Time to break out the long screw driver and have a listen to your motor.
Place the flat blade on different places on the motor with the handle to your ear.
When you find the area with the problem you will hear it. It will help you track own the noise anyways..
Old Jan 31, 2012 | 08:26 AM
AEROplane's Avatar
its coming from the timing chain area maybe valves?
Old Jan 31, 2012 | 08:04 PM
I would start to think its the old timing chain tensioner.
Always a good place to start.
Old Jan 31, 2012 | 08:25 PM
murphy0789's Avatar
Mitch
Yeah I don't know if those would have the same shitty timing chain tensioner if so thats where I would start. Pretty inexpensive party to replace.
Old Jan 31, 2012 | 10:35 PM
AEROplane's Avatar
Saab calls for gm part number 12608580 Timing Damper
I think the cobalt also calls for this???
Old Feb 12, 2012 | 08:54 AM
AEROplane's Avatar
Took it apart found that the balance chain tensioner was gutted the plunger was gone and the guide broken I couldn't find the replacement parts from saab so too a gamble and I ordered them for a cobalt ss and every thing was the same except the balance shaft gears (the ones on mw car was a little thicker) so I reused them other than that all timing componets where the same put it back together and fired it right up and now you can't even hear it run not even a vibration from the engine
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
goaliemo
Sep 28, 2015 01:37 PM
roth
Sep 26, 2015 12:16 PM
