Comp cam springs
Old Aug 7, 2014 | 08:17 AM
mrbelvedere's Avatar
if your going to force the cams to make power past where they were designed to I suggest you learn how to read the plugs and set the timing accordingly to what the plug is showing
Old Aug 7, 2014 | 10:57 AM
SSfamilywagon's Avatar
That's already covered
Old Aug 7, 2014 | 11:28 AM
im sure it is
Old Aug 8, 2014 | 12:06 PM
InfraRedline's Avatar
Never forced the car to do anything. People act like the car goes back to 100whp instantly after you've hit peak power. You are still making more power than you would be shifting and getting back down to say 5500rpms. I had a ported head when my stock cams made power to 7600, stock head would probably taper a bit earlier, but even so, shifting at 7k makes baby Jesus cry. You'll get yanked by he same car shifting a bit higher. If you want, take a dyno graph, and for comparison sake note the hp at every 100 rpms from 5500 to 7000, and then divide by the 16 points you measured hp at, and then do the same from 6000 to 7500 and get the average there as well, that should be all you need to know when to shift. If you want, you can do the same with the torque, and add the 2 together and see what will work best for you.
Old Aug 8, 2014 | 12:57 PM
Our power band hadn't stopped peaking on stock head/cams. I'm just curious where it'll peak.
I have tested shifting early vs late on my cobalt and this car. Its definitely pulls ahead more shifting higher rpm.
Old Aug 8, 2014 | 01:24 PM
It definitely makes a difference, as you said. My friend (the one you met) rides his out to 7450 on the same setup you have. I guess let others do what they wish.
Old Aug 8, 2014 | 02:38 PM
100% METH's Avatar
I made baby jesus cry when my car went to 9600 O_O
Old Aug 8, 2014 | 04:47 PM
Lol ^^^ I wanna know what that feels like
Old Aug 9, 2014 | 09:30 AM
armcclure's Avatar
Knock a blade off a box fan and sit on it with the dial cranked up.
Old Aug 9, 2014 | 10:25 AM
Smooth as butter!!
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
