Compression Ratio: 10.0:1
Old Oct 12, 2008 | 12:57 AM
lafreux's Avatar
At this moment I have gm stage 2 and my friend told me
past fromCOMPRESSION RATIO: 8.0:1 to 10.00:1.
He said I gonna have near 280whp and lot more responce. Is that true?
What do you think of that?
Old Oct 12, 2008 | 01:01 AM
EXsoccer1921's Avatar
wait...you're friend said that adding the stage2 from gm will give you a new compression ratio!?!? up from what it wasn't even at in the first place....and you came on here to find the answer...
talk about face palm
Old Oct 12, 2008 | 01:08 AM
Kennyspec's Avatar
a wise person once told me "just turn up the radio, youll be fine"
Plastic's Avatar
I think these will do
Old Oct 12, 2008 | 01:10 AM
i really am at a lose for words
Old Oct 12, 2008 | 01:15 AM
BLAZIN07SS's Avatar
I'm too JDM for you
please sit your friend in the corner and tell him not to speak anymore.
Old Oct 12, 2008 | 01:20 AM
BLKblurr06's Avatar
I consider myself at least half way intelligent, yet I have no flippin' clue what you are trying to verify....But here's a stab at answering what I think you may be wondering...stock compression ratio is 9.5:1 on typically 15psi if you have stage2..The compression ratio will never change unless you replace the pistons..The 15 psi of boost pressure WILL raise cylinder compression, however the engine by itself only makes a 9.5:1 ratio.. Your friend may have tried to explain that if you raise compression to 10:1 that you would notice increased power or something like that which I wouldnt recommend doing to our cars, raising compression that is
Old Oct 12, 2008 | 01:32 AM
Darkmanx's Avatar
I think he is drunk posting . hopefully
Tupp
Sep 30, 2015 08:18 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
DisJuan
Sep 7, 2015 04:24 PM
