Compression Test with Interesting Numbers?
Old Feb 13, 2010 | 12:48 AM
recklessactn's Avatar
I did a compression test tonight and the numbers cam out 210-210-210-180... I know they are within the normal range of what the numbers should be for a ss/sc. Thoughts?
Old Feb 13, 2010 | 12:50 AM
slowswap's Avatar
Little low on that one. Perform a wet compression test and see if it improves any.
Old Feb 13, 2010 | 01:03 AM
hungryhip-ccp's Avatar
x2 exactly what i was thinking... looks like you had a sticky ring on the last one.
is this a
running?
cranking?
wet?
Old Feb 13, 2010 | 01:05 AM
damien's Avatar
For clarification cyl 1 was the low one. Same result 3 times during cranking. I thought about dropping oil in to see but didnt know if he had any laying around.
Old Feb 13, 2010 | 01:42 AM
^^ hes got the info bc he was there lol, but yea we both were wondering y the one was low, how do you a wet compression test and whats this sticky ring stuff? lol
Old Feb 13, 2010 | 01:51 AM
buckshot3448's Avatar
add a few drops of oil in then do a compresion test if it gets better then you have a bad ring or a stuck ring
Old Feb 13, 2010 | 04:59 PM
so the bad sticky ring... is it something to be worried about or ?
I bought a oil additive today to see if that will get the piston rings back, if not the motor still pulls hard and theres nothing out of the ordinary.
Last edited by recklessactn; Feb 13, 2010 at 04:59 PM. Reason: Automerged Doublepost
Old Feb 13, 2010 | 05:30 PM
selfinfliction's Avatar
couls be the rings have rotated around as well and the gaps are aligned. 180 is acceptable, but when compared to the other 3, yours is out of whack
Old Feb 13, 2010 | 06:06 PM
qwikredline's Avatar
not good. sorry
Old Feb 13, 2010 | 06:16 PM
shroogis's Avatar
Mine did 190 - 190 - 190 - 185 in September...
Yours is a little low, I think they are all supposed to be within 10% of each other, so that 180 cylinder is a little low...
Old Feb 13, 2010 | 09:05 PM
yes i know its bad lol but its like being the shortest kid in the family, ur not retarded or anything ur just short......
Old Feb 13, 2010 | 10:03 PM
a single cylinder with that much difference could throw the harmonics off
Old Feb 14, 2010 | 10:48 AM
.... maybe I dont want to know about these problems anymore... ignorance is awesome!
Old Feb 14, 2010 | 11:41 AM
chevysssc's Avatar
are you sure? cuz I really think Tiff is retarded.
Old Feb 14, 2010 | 12:25 PM
ralliartist's Avatar
That's the WORLD's WORST analogy for explaining an engine problem. Shame on you.
Old Feb 14, 2010 | 01:00 PM
damien's Avatar
I wouldn't worry about it one bit. Here's why:
A friend of mine built a 500awhp DSM. Cyl #'s were 140-180-180-180. Car ran AWESOME and still takes a daily beating. Cause of the problem isn't a piston ring.
Old Feb 14, 2010 | 01:05 PM
your friend is an idiot if he "built" a strong engine like that and didn't care that a single cylinder was 40 psi off the rest
sounds like someone who "built" a motor by bolting an unnecessarily large turbo on an old worn out engine
Old Feb 14, 2010 | 01:29 PM
damien's Avatar
Sounds like you need to stop guessing about other builds. You must have missed the part where I said 'built'.
Max i'm done in here. If you want to redo it on that 1 cyl with oil let me know we'll figure something out.
Old Feb 14, 2010 | 02:55 PM
nah i didn't miss it, it just proves that your friend is a dumb individual
Old Feb 14, 2010 | 03:00 PM
we will be in touch my friend :-) after i shovel my driveway this time though lol
Old Feb 14, 2010 | 10:15 PM
Karlen89's Avatar
O MY. I lawled hard on that one. Going in my sig now. ROFL
Old Feb 16, 2010 | 03:24 PM
Haha o comeon its just a bit of sarcasm, i know being short has nothing to do with compression testing
Thank you sir!
Old Feb 17, 2010 | 06:06 PM
chevysssc's Avatar
dave said we can use his leak down if you need to
Old Feb 18, 2010 | 10:34 PM
chevysssc's Avatar
leak down showed 20% loss
hacadacalopolis
Oct 28, 2015 06:09 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
metroplex
Sep 27, 2015 07:48 AM
