Connecting Wideband via AC Pressure Switch for HPT
I've had a thread about this before but didn't get the answers I needed. There use to be a how-to supposedly but it has disappeared. I have the Innocate LC-1 and HPT standard. I just need the steps to finding the ac pressure switch and what to do. I have the info about pulling it up in HPT.
Checking interwebs.......... http://www.ls1tech.com/forums/pcm-di...thout-eio.html might help until I can find the one that is here.
This one's not too bad:
http://forums.corvetteforum.com/c5-s...hp-tuners.html
Ya. I've read that Corvette one. But what I don't understand. Do I tap a wire into the ac pressure switch from the wideband to the switch? And what wideband wire do I tap in to?
From what I understand you are putting the signal wire from the wideband into the AC pressure signal line. Then in HPT you are using the signal coming from AC pressure as your wideband signal instead. So for it to work, you can't have the AC on while logging. If you add a switch you can make sure you can turn off the wideband after logging so your AC pressure is sensed correctly. That's my take on it - haven't done it yet........HPT coming with my TVS, but still making payments............
Haha. Hey guys, I'd listen to Kenny - I think he said in another thread he did the origina how to that is now missing (probably due to HPT being a vendor and not liking it - a guess).
n20saturn
09-30-2015 12:26 AM
