coolant temps really low
so lately my coolant temps have been around 145-165 F. only when i sit for a while do they go up to 180. i was wondering why this could be happening. btw, its not insanely cold here. it fluctuates between 50 and 80 F here. i was wondering if ill need a new thermostat??
**** me. I have the same problem.. While driving my coolant temps are roughly 163-171°F.. But it only started happening now that it has gotten cold, and by cold I mean 30°F.. My heat still blows like a New York hooker so I'm not sure.
i think it might be time for me too lol. i got a check engine light the other day for "coolant temp low". used to run around 200 but now its sits about 175-185
Yeah sounds like you guys could all use new ones. dealer should take care of it if it's under warranty. I had mine replaced last year when it stopped reading completely, it was stuck open.
thanks for the feedback you guys. im gonna get underneath it and see if i can get my hands on this puppy. but i hear its pretty difficult. ah well, might as well try. i have to change my oil, plugs and front o2 anyways. might as well try it.
what kind of price would i be looking at if i had the dealer replace my thermostat??
I just replaced my thermostat, I was seeing coolant temps as low as 120 on the highway before doing so. After replacing, I've been seeing around 175 with constant fluctuation. It will usually register 172-176 dependent on driving conditions. The temperature will hang at 172 for a few seconds, then go up to 174, then 176, then back down to 172, pretty much constantly. If you accelerate away from a light, it will drop to 169ish, go back up then fluctuate, thoughts?
z28addiction
Sep 28, 2015 12:03 AM
