coolant temps really low
Old Nov 16, 2010 | 09:47 PM
GM COBALT SC SS's Avatar
so lately my coolant temps have been around 145-165 F. only when i sit for a while do they go up to 180. i was wondering why this could be happening. btw, its not insanely cold here. it fluctuates between 50 and 80 F here. i was wondering if ill need a new thermostat??
Old Nov 16, 2010 | 10:24 PM
jdunn622's Avatar
my coolant temps have been around 150, its because its getting colder outside so ur car is sucking in a lower intake temp allowing ur engine to run cooler
Old Nov 16, 2010 | 10:25 PM
09xfebalt's Avatar
time for a thermostat....both of you.
Old Nov 16, 2010 | 11:38 PM
any other comments??
Old Nov 17, 2010 | 12:06 AM
AndrewSS/TC's Avatar
You need a Thermostat. When I run my heat my temp sits between 195-198, without heat still cold outside though it stays 188-190.
Old Nov 17, 2010 | 12:14 AM
07sscobaltss's Avatar
I think operating temp on this car is 185-195ish? so thermostat for sure
Old Nov 17, 2010 | 09:07 AM
xxxxsh4d0wxxxx's Avatar
**** me. I have the same problem.. While driving my coolant temps are roughly 163-171°F.. But it only started happening now that it has gotten cold, and by cold I mean 30°F.. My heat still blows like a New York hooker so I'm not sure.
Old Nov 17, 2010 | 10:33 AM
mrbelvedere's Avatar
lmaorotf
Old Nov 17, 2010 | 10:37 AM
importkiller's Avatar
New thermostat is in order, same thing happend to my budies 2.0t saab (a cousin to our cars) and once we put in a new thermostat it was fixed.
Old Nov 17, 2010 | 10:40 AM
09Sp0rt's Avatar
Mine sits at 190 all the time
Old Nov 17, 2010 | 10:58 AM
BlackCobalt707's Avatar
i think it might be time for me too lol. i got a check engine light the other day for "coolant temp low". used to run around 200 but now its sits about 175-185
slobalt22's Avatar
183 is normal running for mine
Old Nov 17, 2010 | 11:36 AM
Tundraboarder666's Avatar
Yeah sounds like you guys could all use new ones. dealer should take care of it if it's under warranty. I had mine replaced last year when it stopped reading completely, it was stuck open.
Old Nov 17, 2010 | 02:38 PM
ULWizSS's Avatar
179 is average for me. Usually only go into the 200's at the track.
Old Nov 17, 2010 | 06:23 PM
thanks for the feedback you guys. im gonna get underneath it and see if i can get my hands on this puppy. but i hear its pretty difficult. ah well, might as well try. i have to change my oil, plugs and front o2 anyways. might as well try it.
what kind of price would i be looking at if i had the dealer replace my thermostat??
Old Nov 17, 2010 | 10:04 PM
09xfebalt's Avatar
I have not dont one on a SC ecotec but it takes between 5-10 minutes from the top side on a 2.2-2.4.
Old Nov 17, 2010 | 10:16 PM
LS6Rally's Avatar
yea, its a t-stat. my 2.4 was running at about 160 constantly. puit a new one in and its back to 188-196. Stck t-stat is 180* ona 2.4
Old Nov 17, 2010 | 11:01 PM
ROTARYFDTT's Avatar
I just replaced my thermostat, I was seeing coolant temps as low as 120 on the highway before doing so. After replacing, I've been seeing around 175 with constant fluctuation. It will usually register 172-176 dependent on driving conditions. The temperature will hang at 172 for a few seconds, then go up to 174, then 176, then back down to 172, pretty much constantly. If you accelerate away from a light, it will drop to 169ish, go back up then fluctuate, thoughts?
Old Nov 17, 2010 | 11:04 PM
05Slowline's Avatar
^ about where mine sits, heats up to 180+ if i sid idle a few mins but 175 or so cruising
brandon04
Oct 21, 2015 07:04 AM
Slick_Nick
Sep 28, 2015 09:15 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
