cooling Mods
Old May 11, 2008 | 10:25 PM
hatrickstu's Avatar
Originally Posted by Maxim_X
Not really. An aftermarket Heat exchanger does minimal work. GO for a beat run and feel your H/E, it wont even be that hot.
The do a dual pas, the dual pass allows the coolant to stay in the manifold for half the time. Their for the coolant does not heat soak and it keeps transferring the heat instead of becoming hot.
If yo go for a beat run after you install a dual pass you will notice your stock H/E will become hot. The after market H/E compliments the stock H/E when you have dual pass installed.
Somewhere in the words of ss.net past someone said that a after market h/e alone made a big difference. It's a common misconception.
one of the guys that was making HE for our cars actually claimed that his dropped IAT2's by 50*, whether or not it was true, i have not seen any evidence of
Just so you know. With HP tuners you can turn your pump to 100% all the time such as mine is, You can also make it run when the car is in "ON" and not running to make in intake manifold cold to the touch in about 5 minutes. Try touching your intake manifold after 5 minutes.
I think that pump tuning along with the dual pass was the most effective of my cooling mods.
a how-to on this would be greatly appreciated
Last edited by hatrickstu; May 11, 2008 at 10:25 PM. Reason: Automerged Doublepost
Old May 11, 2008 | 10:34 PM
compucarnut's Avatar
Not to hijack the thread, but I just did a cobra h/e, and anytime I pull over and put my hand to the cobra h/e, it feels completely cold...like fluid is not even running through it. Normal?
Old May 11, 2008 | 10:43 PM
ralliartist's Avatar
first question, I questioned him and he couldn't provide any evidence. His actual claims where that it outperformed the CXRacing and Stock Cobra h/e. But he never provided any proof. So instead of posting the proof, he just deleted the threads.
2nd question, hell yea, please give us a how too or pm us with directions. I wanna know!
sounds normal!
Last edited by ralliartist; May 11, 2008 at 10:43 PM. Reason: Automerged Doublepost
Old May 11, 2008 | 11:36 PM
SJSchafer's Avatar
Originally Posted by ralliartist
Where is it that you make the changes for the pump to run 100% and in the ON position in HPTuners?
I circled it in red:
Old May 12, 2008 | 10:24 AM
hatrickstu's Avatar
that will get the pump to run with it just on the ON position?
Old May 12, 2008 | 10:57 AM
SJSchafer's Avatar
Yep:
Intercooler
Intercooler: Indicates if an intercooler pump is fitted to the vehicle.
Intercooler ERT Min: Minimum engine run time to enable intercooler pump.
Intercooler IAT Min: Minimum intake air temperature to enable intercooler pump.
Old May 12, 2008 | 01:49 PM
hatrickstu's Avatar
just did that, did nothing. no fluid flowing at on position, only when running
Old May 12, 2008 | 02:08 PM
SJSchafer's Avatar
That is odd. With the settings as shown on the pic, you should be able to turn the car to the "on" position and hear the pump running. You can also open the VCM scanner, go to VCM controls>general. Click the intercooler pump on button.
Old May 12, 2008 | 02:19 PM
hatrickstu's Avatar
i actuallyt think the pump might be acting up in general. im about to PM you some stuff
Old May 12, 2008 | 02:25 PM
SJSchafer's Avatar
otay
Old May 12, 2008 | 02:32 PM
  #36
n8g's Avatar
n8g
Good stuff in here. I will make sure my tuner makes the adjustments. Although, I don't want the pump to always be running. Or do I?
Old May 12, 2008 | 02:33 PM
  #37
hatrickstu's Avatar
it wont always be running, it will be running whenever the car is ON, and yes you do want that
Old May 12, 2008 | 02:43 PM
  #38
SJSchafer's Avatar
Absolutely.
Old May 12, 2008 | 06:00 PM
  #39
rico's Avatar
so even just having a second h/e and doing the pump set up to always be on helps? nothing wrong with having the pump on all the time?
Old May 12, 2008 | 06:09 PM
  #40
SJSchafer's Avatar
correct.
Old May 12, 2008 | 06:10 PM
  #41
rico's Avatar
oh sweet im new at all this so this info really helps lol. and ill keep that in mind for when i get it on and all
Old May 13, 2008 | 10:55 AM
  #42
n8g's Avatar
n8g
So what are the pump settings from the factory? It seemed last night that it turned on almost as soon as I started the car.
Old May 13, 2008 | 11:33 AM
  #43
Area47's Avatar
Rent me! per hour
settings are 10 seconds.
bigdeertz
Nov 17, 2016 09:41 AM
dennis69
Oct 20, 2015 04:49 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
