Couple of issues with my lsj
Old Jun 28, 2010 | 04:03 PM
redline4's Avatar
Well ever since I got my motor back I've been getting a few problems that I can't figure out
The first one being is i can't seem to get the Cam to Crank correlation CEL to go away and I've followed the directions on putting the camshaft position sensor in still no luck
Secondly the other night i was driving home and my ABS light came on while it was raining well I stopped the car and turned my car off and wouldn't start back my battery was completely drained. Well my buddy boosted me off and she was charging and battery was good(Got a System checking machine) at work. With that machine i checked the alternator, battery and cranking to see if there was a problem well all tested well above normal spec. Well today my abs light would come on and flash then when I hit my brake my damn radio would turn off and would come back on once i let off the brake weird as **** i tell ya. Only i can think of is i put new rotors and pads around 2 weeks ago and it didn't do anything until friday.
Third, When I turn on my air I hear a weird noise coming from the passenger side front of the car. At first I thought it was my ac compressor but I can't hear it when i look under the hood only when im inside the car. Blower motor maybe?
Old Jun 28, 2010 | 04:29 PM
Karlen89's Avatar
The weird noise you hear when you turn the air on is the a/c fan blower motor. The bearings fall apart. Not much you can do about that.
Old Jun 28, 2010 | 05:19 PM
06cobalt racer's Avatar
did u disconnect the abs plug? did u plug it back in??? idk just guessing
Old Jun 30, 2010 | 10:53 PM
redline4's Avatar
Nope didn't unplug the abs. It feels like when it does happen that something is draining my power and my lights go dim and my power steering slightly goes.
Old Jun 30, 2010 | 11:19 PM
Dainslaif's Avatar
Check your ground wire in the engine bay. Sounds like you have a short somewhere.
Old Jun 30, 2010 | 11:29 PM
redline4's Avatar
yep checked that out as well and all is good.
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Tupp
Sep 30, 2015 08:18 PM
Sep 28, 2015 12:51 PM
