A couple stage three questions
Old May 10, 2013 | 01:15 PM
  #51
Hockeyman's Avatar
Originally Posted by Dfields
Can someone please explain the two cooling systems??? I did not put any water in my car and the only place I added the 50 50 mix was the big hose on the top of the motor?? What am I doing wrong??
Jesus man, we are trying to help you. Read my posts, the answer is already there.
Old May 10, 2013 | 01:16 PM
  #52
Dfields's Avatar
Oh ok so I just filled the normal system... But I don't have the option b I only have one fill tank..
Old May 10, 2013 | 01:21 PM
  #53
Sir_Hiro's Avatar
He doesnt have Option B..Im helpin him on FB now
Old May 10, 2013 | 01:26 PM
  #54
Hockeyman's Avatar
Fill cap, in front of the supercharger. Fill it up.
  #55
yellowsupercharged06's Avatar
can someone please go help this kid out ???
Old May 10, 2013 | 01:30 PM
  #56
Sir_Hiro's Avatar
Im going to his house in a hour or two to help
  #57
Dfields's Avatar
I got all confused lol didn't realize their is two different cooling systems... So after filling up the Ic that will hopefully bring my iat readings down to normal??
Old May 10, 2013 | 01:31 PM
  #58
your a good man lol ....
make sure he knows what he is doing before his next mod so he dont hurt the car lol
Old May 10, 2013 | 01:32 PM
  #59
Hockeyman's Avatar
If your IC pump is working, then yes. Hopefully you didn't harm it by running it dry.
Old May 10, 2013 | 01:42 PM
  #60
Dfields's Avatar
Hey hey I ain't a ******* I did everything right just never knew their was two different cooling systems... And imma keep my fingers crossed I didn't break the pump
Old May 10, 2013 | 01:49 PM
  #61
Gelladuga69's Avatar
Pumps on these cars die all the time. Don't be surprised if it is broke. Where are you in MI?
Old May 10, 2013 | 02:00 PM
  #62
Dfields's Avatar
Near Romeo ok so my pump is prolly gone then lmfao that sucks lol... Anybody know how to test the clutch switch to see if it works
Old May 10, 2013 | 02:25 PM
  #63
The one towards the bottom of the pedal you can play with and check. Easy to replace.
The one up in the dash.. Not sure.
Old May 10, 2013 | 03:07 PM
  #64
Dfields's Avatar
My issue is when turning the key it acts like the clutch isn't being pushed in even though I'm pushing the clutch in so thinking it may e the clutch switch??
Old May 10, 2013 | 03:27 PM
  #65
Vander Nars's Avatar
U didnt do everything right if u filled the wrong system lol.
http://youtu.be/qAjJXB_CNkQ
Old May 10, 2013 | 04:06 PM
  #66
Dfields's Avatar
Damn it lol I wish I woulda seen that video a couple days ago
Old May 11, 2013 | 05:01 PM
  #67
Dfields's Avatar
So for all you guys saying it was the starter that's not the case I put a new starter into it today and its still doing the same thing acting like the clutch isn't pushed in
Old May 11, 2013 | 05:33 PM
  #68
Did you check out the white switch at the bottom of the clutch pedal?
Old May 11, 2013 | 05:39 PM
  #69
Dfields's Avatar
Ya I just took it off and I'm looking at it from what I can see it works fine it makes the too copper prongs touch eachother
Old May 14, 2013 | 09:48 PM
  #70
Dfields's Avatar
Ok so after scratching my head for a few days I jumped back into it I took the supercharger back off as well as the intake so I'm back down to nothing...is their anyone that can think of anything I could do to possibly gett it running any hidden grounds could be cleaned anything I should test??? And one question the wire on top of the starter the bigger of the two posts has two wires connected to it one goes to the positive on the underhood fuse box the other to the stud on the alternator??? Thanks for your help guys
Old May 14, 2013 | 10:13 PM
  #71
blueLNFftw's Avatar
Originally Posted by BoSStwick
I strongly disagree with the idea of an option B, I have AIT temperatures huddle around 110-130 in 70 degree weather with zzp dual pass and the zzp heat exchanger. The key is to keep opening up your cap to let the air escape, refill with coolant, then tighten it, turn the KEY on (don't start the car), keep the pump working for roughly a minute, turn the pump off, open the cap again and repeat. This took care of all the bleeding I had to do. Also buy an Aeroforce interceptor gauge like me, it gives you steady readings of your IAT2's which will basically tell you if your pump fails. Its all worth it, and could save you money later on.
And if your pump fails like mine did, ZZP sells them for $100 on their site.
except that the GM tunes do not turn the IC pump on with the key to ON. car has to be running.
Old May 15, 2013 | 10:58 PM
  #72
ThexGovenor's Avatar
I actually went to romeo high school. where abouts do you live?
Old May 16, 2013 | 12:00 AM
  #73
RDY2RAC's Avatar
If you haven't already bought a dual pass endplate I would highly recommend getting one, your IAT2 should be around 20 °F above the outside temp... also, make sure your lines are going the right direction from your stock heat exchanger into your new one... as far as the wiring goes, stop buy auto zone and grab a Chilton manual, everyone on here can help but its best if you can see exactly how it is supposed to go and have a guide right in front of you! I had a similar problem with my clutch and it ended up being my throw-out bearing... best of luck to you and once its all straight enjoy the hell out of the new boost!
Old May 16, 2013 | 12:37 AM
  #74
Sir_Hiro's Avatar
He has one.
A dual pass I mean.
Old May 18, 2013 | 04:59 PM
  #75
Dfields's Avatar
I live in armada....I took the battery in to get it check and it failed the test so I gotta put everything back together and buy a battery to test it
