Coupler Possibly? Video Included!
Old Feb 21, 2009 | 04:52 PM
Sythen1678's Avatar
Boost Loss Please help! Video Included!
So after the countless threads of supercharger noise i feel as if its the Coupler, or possible problem with the rotors however i just had my supercharger replaced under warranty not even 3000 miles ago.
The other problem i run into if ever since the noise, Im boosting 12 lbs rather then 16.
You guys let me know, and Thank you for looking!
http://www.youtube.com/watch?v=CL_yj3q7264
Old Feb 21, 2009 | 04:55 PM
Caivn's Avatar
it sounds like there is something in the fins of the blower or the fins are hittin each other
Old Feb 21, 2009 | 05:30 PM
Sythen1678's Avatar
Im going to take it apart tomorrow and see what's going on. Its possible the teflon on the fins are jacked up which is not pressurizing the air properly resulting in lowered boost.
Has anyone Replaced the bearings before?
Old Feb 23, 2009 | 05:03 AM
Sythen1678's Avatar
Bump!
Old Feb 23, 2009 | 05:12 PM
JCobalt's Avatar
when the bearings on my blower went the rotors colided and messed up the rotors and case. i didnt have the money to replace the blower so i had it rebuilt. the guy had trouble because of all the damage and the rotors ended up not sealing so with a 2.6 pulley i was only seeing 15 psi instead of 19 psi. so it sounds like the clearances arent right probably do to the bearings or something of that nature. you probably need another blower
Old Feb 23, 2009 | 06:49 PM
Sythen1678's Avatar
I popped her open today and found it shredded, im posting pictures in a little
Oct 21, 2015 11:57 PM
HEATON
Oct 16, 2015 07:21 PM
jimbofug007
Oct 2, 2015 12:06 PM
