crank shaft sensor
Old Dec 3, 2009 | 09:28 AM
jonathan923's Avatar
crank shaft sensor
does anyone know if theres such thing as crankshaft sensor activation after its been installed?
Old Dec 3, 2009 | 11:06 AM
SilverG85SS's Avatar
...no.
there should b a crank relearn procedure ull have to go thru, and u cant, unless u have a tech II. which is like $3000.
Old Dec 3, 2009 | 11:36 AM
stonny9's Avatar
Originally Posted by SilverG85SS
...no.
Get ur facts straight noob. You can do crank case relearn with HPT I have done it twice on my car. Your car has to be up to operating temp before HPT will let u select and takes all of 30 sec to do.
You can still start ur car it will just take a few sec to start but otherwise runs fine even with the DTC cose for the crankcase sensor out of sync
edit: I see the Op is in Miami. Italianjoe1 has HPT and may be able to do it for u for a small fee. PM him. He is a nnice and knowledgable kid even though he no longer has an lsj.
Old Dec 3, 2009 | 11:41 AM
AnthonyCM's Avatar
yeah just use HPT u don't even have to unlock your car on HPT to do it either
Old Dec 3, 2009 | 11:24 PM
wtpcobaltss's Avatar
tech 2 or dealer or hpt
Old Dec 3, 2009 | 11:26 PM
ItalianJoe1's Avatar
I replaced mine and it didn't even set a code, you may need a CASE relearn though, but as said it can be done through the HPT scanner. Let me know if you need that done, I may be able to help you out.
Old Dec 4, 2009 | 12:01 PM
great thanks to all. I-joe ill let u know and ill get to you through richard (black SS s/c on Boost) thanks alot man.
Old Dec 7, 2009 | 10:31 PM
sorry i dont have hp tuners. i didnt kno that, my bad
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Stuff
Oct 1, 2015 05:47 PM
jmelton327
Sep 26, 2015 10:04 PM
