Cryo2 System Install! 56K No problem
Old Dec 2, 2007 | 09:05 PM
spike's Avatar
i would like 2 know what iat2 temps are with this
Old Dec 2, 2007 | 09:07 PM
memphisr24's Avatar
Wait...cry02 goes into the engine? I thought it wasj ust an intercooler sprayer kind of thing
Old Dec 2, 2007 | 09:08 PM
matt_SS_205's Avatar
no it does not go into the engine, if your refering to it going in the intake it goes through the tubing into a 'bulb' like thing and back out the other side of the intake
Old Dec 2, 2007 | 09:11 PM
AlphaJaguar5's Avatar
Check out their website, there are a ton of different ways to utilize their product. However, matt is correct, you don't actually spray it "inside" your intake stream.
Old Dec 2, 2007 | 09:13 PM
memphisr24's Avatar
See i've been on their website a bunch of times but I don't understand how you use it...which is why I never really researched it that much. I tried to understand it but my puuny brain can't take in the info lol
But yeah, i'm looking forward to Bill's logs
Old Dec 2, 2007 | 09:15 PM
lol i didn't understand it at first, but once i did it's actually really simple
Old Dec 2, 2007 | 10:15 PM
BlilBT's Avatar
Originally Posted by AlphaJaguar5
lol, Bill is one of my best buddies and part of our car club, yes I'm joking. If I wasn't I'd be a *****
His car is always flawless and the same goes with this mod. Looks great as always and you know if its on Bill's car it should be on your car.
I'm not going?
Who's the one getting the V.I.P. passes for everyone then? lol
Alpha always causing trouble, I didn't Know you registered. Ok then Alpha will be there 2!
Old Dec 2, 2007 | 10:33 PM
jsscooby's Avatar
I never heard of these things. seems kind of neat
Old Dec 3, 2007 | 01:44 AM
BlueSS-supercharged's Avatar
been waiting for some one to buy one of these kits. . .i just always thought we couldnt use one with the heatexchangermabobthinggyyy. but i guess so. really curious if it has a better effect then meth, wich i always thought but then got discouraged cause no one did it yet. YAY for BLILBT, his car continues to own all of ours
Old Dec 3, 2007 | 02:19 AM
elecblue06's Avatar
looking forward to seeing the benefits of this i swa this a while ago and looked at it as an alternative to no2 since it's usually cheaper and seems safer to me but i've never seen any results for our cars good luck man
Old Dec 3, 2007 | 08:11 PM
  #36
BlilBT's Avatar
I let you Know what it does soon, Just need to get some time so I can go driving & Heat it up to see what happens when you hit the Button!
I Know I am also curious to see & your right it is alot safer than some of the alternatives that are out there. I Need to get the Intake setup to really benefit, Soon enough tho waited this long can wait couple more weeks!
Old Dec 3, 2007 | 09:39 PM
  #37
advise's Avatar
think its small enough to fit between the condenser and the stock h/e
Old Dec 3, 2007 | 09:47 PM
  #38
BlilBT's Avatar
I dont think it would! Thats why you get the Intake setup, if you dont have a aftermarket H/E
Old Feb 24, 2008 | 01:27 PM
  #39
rockkrawler628's Avatar
how bout an update man... i'd love to see what it does compared to meth
Old Feb 24, 2008 | 01:28 PM
  #40
lsjwannabe's Avatar
no comparision, meth will make more power tuned period.
Old Feb 24, 2008 | 03:50 PM
  #41
-Jayson-'s Avatar
he didnt update cause he realised this is crap for our cars. Intercooler spayer bars work fine on Air to Air intercoolers, but on a water to air intercooler not so well. The problem is is that the water is a hell of alot denser than the C02 being spayed onto it as compared to air. There fore it needs to remove alot more heat from the water to bring the temps down than it does with air to bring the temps down. Something that i just dont see happening very easily.
Old Feb 24, 2008 | 07:43 PM
  #42
BlilBT's Avatar
I didn't update it because the weather is to cool to get a good comparison, You don't need cool air when you already have it! Plus I'm also running the dual pass & did 4 dyno runs & Ran My strongest pull on the 4th run, So I can tell you I don't Loose power to heat soak. By the way I'm not just running the Spray bar it's actually just the purge & when I do get the temps to give it a shot we will see what the system does, Either way I will post results when I get them. As far as the spray bar it does help lower intake temps while spraying but not as Much as the Intake itself!
So learn the facts before you Pop off Makes the community a Better place!
Old Feb 24, 2008 | 08:12 PM
  #43
-Jayson-'s Avatar
post some dyno numbers and logging then. There should be a very obvious correlation betweeb HP and intake temps if your claiming your strongest HP pull was due to the Cryo02 system.
Nothing you have posted is facts, so far all you made was a claim. A claim that might only be a difference of 5HP or just the non consistency of a dyno anyways. Or that the 4th pull was stronger because the engine was heated up to its optimal running temps. Last time i was on a dyno, i did 3 runs, guess whcih one was my strongest pull? (pspssttt 3) i have no cooling mods whatsoever.
I am trying to make the community look better, its hard weeding through all the bullshit that gets spewed on this forum, there are enough kiddies and leg humpers on here to make me believe santa clause is a 16 year old piece of jailbait ass riding in a 500HP stock block LNF AWD Cobalt that deliveries sexual pleasure on an unheard of level on Dec 25th.
Old Feb 24, 2008 | 09:22 PM
  #44
BlilBT's Avatar
Well try harder because in another thread I did post some dyno runs>>> But you do what you want! Like I stated above when all the things are done & temps are good the info will be available till then I guess you will have to wait! Last I anit no Kid & have been here helping this site long before you!
Old Feb 24, 2008 | 09:33 PM
  #45
anthonyS88's Avatar
amen to that, Bill is the man...
Old Feb 24, 2008 | 09:37 PM
  #46
R&C_rallySS's Avatar
Yea I Decided to go with the Kit & it didn't come with the Intake>> But I will have it real Soon!
The Kit list for $489.00 with 10lb tank & $373.00 For the 5lb Tank!
They have results showing a 9% gain in HP to a N/A Civic, Thats Not bad! But I will tell you what it does with Hp Tuners after i get a chance to scan it!
Should be better gains with a F/I car. Cold air is always good, but its great for turbo and superchargers. Good luck, I hope to see a 10-12% gain.
^ That is the only amusing part of your entire post.
Last edited by R&C_rallySS; Feb 24, 2008 at 09:37 PM. Reason: Automerged Doublepost
  #47
Darkmanx's Avatar
Bill there is a dyno day in broward on peters road on march 22 . 3 runs plus A/F for 35 dollars.
Old Feb 24, 2008 | 09:47 PM
  #48
BLAZIN07SS's Avatar
I'm too JDM for you
more info please...
Old Feb 24, 2008 | 09:51 PM
  #49
Coblt ss super's Avatar
how do u get sponserships?
Old Feb 24, 2008 | 09:52 PM
  #50
Darkmanx's Avatar
There is 2 conflicting dynos happening on march 22 . ONe at twilight performance in miami and the next one on peters rd But i think the twilight one is getting pushed back because there both friends. ill get the info for you man
