Cryo2 System Install! 56K No problem
Old Oct 6, 2008 | 06:23 PM
  #51
impulseballer's Avatar
lol at no update
Old Oct 6, 2008 | 06:46 PM
  #52
Viper33884's Avatar
WOW that's a very clean looking install. Nice job.
Old Oct 6, 2008 | 06:48 PM
  #53
BlilBT's Avatar
Originally Posted by impulseballer
lol at no update
Dude if I had time to do anything with it I would, but last 6 months have made me refocus on a few other things! I haven't had time to worry about my car latlely sorry, but I will be picking up were I left off soon enough things are looking better!
Old Oct 7, 2008 | 10:56 PM
  #54
SCcobaltSS's Avatar
^Damn I have had this kit for about 3 months and havent got time to install it... But I need the spray bar for the heat exchanger and dont want to pay that much money... I think I will fabricate my own for about 10 dollars!
I have the intake bulb, but dont like the idea of the buld taking up that much space in the intake...
Old Sep 12, 2009 | 10:00 AM
  #55
chevysssc's Avatar
Originally Posted by -Jayson-
he didnt update cause he realised this is crap for our cars. Intercooler spayer bars work fine on Air to Air intercoolers, but on a water to air intercooler not so well. The problem is is that the water is a hell of alot denser than the C02 being spayed onto it as compared to air. There fore it needs to remove alot more heat from the water to bring the temps down than it does with air to bring the temps down. Something that i just dont see happening very easily.
but Co2 is denser air and air is what cools the water. but thats not the reason for the cooling, if you had this system you would understand that the Co2 freezes the alum. H/E that the water passes through. i have this and with a 7 sec burst the spray bar dropped water temp by almost 5* yea i know not much but it did somthing. and thats not even the main part of the system that where the used Co2 exits.
Old Nov 1, 2009 | 09:42 AM
  #56
buellfooll's Avatar
Good read. These guys impartial. They aren't trying to sell anything
http://www.cryofuzion.com/spraybar.htm
Old Nov 1, 2009 | 10:02 AM
  #57
selfinfliction's Avatar
sure they're impartial , they're trying to sell something called the "interfreezer" that does exactly what they talk bad about on the spray bars
guess i'm dumb cause i just don't get how the "interfreezer" is so much better because it's basically the same thing as a spray bar, except it's inside the intake and restricting flow
Old Nov 1, 2009 | 10:12 AM
  #58
buellfooll's Avatar
Read the whole thing. The part where they had to cut a hole in the wall of the dyno room to get FRESH, not contaminated, air into the engine. Unless you have an engineered ducting system enough CO2 will enter the air intake to REDUCE engine power output.
Old Nov 3, 2009 | 06:11 PM
  #59
Cobaltsky05's Avatar
Originally Posted by BlilBT
Yea I Decided to go with the Kit & it didn't come with the Intake>> But I will have it real Soon!
The Kit list for $489.00 with 10lb tank & $373.00 For the 5lb Tank!
They have results showing a 9% gain in HP to a N/A Civic, Thats Not bad! But I will tell you what it does with Hp Tuners after i get a chance to scan it!
I don't see how it can increase horsepower without having someone tune your car with advancing the timing to achieve more power. Just lowering Intake Air Temps doesn't make more power. Just makes it possible to push timing further to make more power.
Old Nov 7, 2009 | 12:09 PM
  #60
chevysssc's Avatar
doesnt your car feel faster in the winter?
Old Nov 7, 2009 | 02:02 PM
  #61
maybe slightly and I live in WA where the temps are all over... like honestly don't know if my PCM ever can keep up. Lot's of elevation change around where I live and around the bay at sea level it feels the fastest.
Old Nov 7, 2009 | 02:29 PM
  #62
chevysssc's Avatar
it is because of denser air at sea level and cold air is dense air.
Old Nov 7, 2009 | 03:07 PM
  #63
I can agree with that statement and more air can make more power with more timing and more fuel, but only if the ecu reads this and calibrates for it. My ecu doesn't... I have a stock maf and stock map sensor on my setup with a trifecta tune so it's constantly hunting for idle when I don't let it warm up thoroughly and at WOT I see a 9.8 AFR :-( would think colder temps would have helped lean me out but it's done the opposite with my ecu. I will be getting better sensors soon and HP tuners and see what happens... BOOM!
Old Nov 8, 2009 | 12:44 AM
  #64
yeah i read the whole thing and it shows they designed a device that flows co2 through the intake system. there's no way they tested every single fmic with a spray bar on the market.
they are selling snake oil, ricer snake oil at that.
turbochargedss2012
Sep 20, 2023 12:17 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
