Custom Option B brackets?
Old Jan 23, 2011 | 03:38 PM
07BoostedG5's Avatar
Originally Posted by qwikredline
Fail. You do.
tell that to my perfectly running system and ice cold m62......../.
Old Jan 23, 2011 | 03:39 PM
05Slowline's Avatar
Originally Posted by 07BoostedG5
fail you
sorry if you don't have a restrictor in your option b bleed line you do fail. learned this 2 years ago.
Old Jan 23, 2011 | 03:45 PM
why? and no need for this fail **** christ, talk like humans...
Old Jan 23, 2011 | 03:47 PM
05Slowline's Avatar
purpose of the bleed line is to bleed air not coolant......fail
if the tanks open line is above the coolant level by 2ins how will coolant escape?
Old Jan 23, 2011 | 03:50 PM
05Slowline's Avatar
above the coolant by 2 inches on the tank not on the heat exchanger...
option b with a restrictor in it wrong size though...too big...you get the idea.
Last edited by 05Slowline; Jan 23, 2011 at 03:50 PM. Reason: Automerged Doublepost
Old Jan 23, 2011 | 03:51 PM
???? what do you mean
Old Jan 23, 2011 | 03:53 PM
05Slowline's Avatar
what do you mean what do i mean you tap the heat exchanger for the bleed line coolant moves through the heat exchanger no restrictor in that line from heat exchanger to tank and you have fail
Old Jan 23, 2011 | 03:55 PM
mmm....
Old Jan 23, 2011 | 03:56 PM
05Slowline's Avatar
if you have no restrictor in your line then your tank return looks like the video i posted. this isn't something that i'm pulling out of my ass it's gm research from years ago that has been proven.
Old Jan 23, 2011 | 03:57 PM
  #36
but it doesnt look like that is what im trying to say
Old Jan 23, 2011 | 03:58 PM
  #37
05Slowline's Avatar
right, whatever ya say if you have no restrictor in that bleed line you're getting coolant traveling out the line not air
Old Jan 23, 2011 | 04:07 PM
  #38
You know what..........Im sorry for the misunderstanding, I just looked and sure enough I have a restrictor there, I was thinking something completely different my bad dude.
Old Jan 23, 2011 | 04:09 PM
  #39
05Slowline's Avatar
haha
Old Jan 23, 2011 | 08:01 PM
  #40
Originally Posted by ssyellow
Could someone post up a link or picture of what exactly the barb restrictor is? Having trouble finding it. Also, where does it go in relation to the plumbing? Closer to the tank or near the bleed hole on the stock heat exchanger?
go the ced website, what it is, is an insert you put inside the hose that makes the passage smaller, then you plug that hose end with the restrictor into the a barb fitting, (1/8th thread) and then that barb fitting replaces the stock HE bleed plug.
Old Jan 23, 2011 | 09:40 PM
  #41
ssyellow's Avatar
Yeah I did some research on another forum and have all that figured out now. What does your one bracket look like? The one on the closer left hand side of the tank.
Old Jan 23, 2011 | 09:44 PM
  #42
Just a stainless L bracket I fabd up.
Old Jan 23, 2011 | 11:14 PM
  #43
ssyellow's Avatar
Ah alright. Does it just kind of slide in the crack there? Didn't really see a spot to mount it.
Old Jan 24, 2011 | 12:22 PM
  #44
exactly^
ineedacobaltss
Nov 7, 2015 02:25 PM
patooyee
Oct 15, 2015 05:11 PM
importkiller
Sep 30, 2015 07:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
