cx racing (small one) clean install w (pics)
Old Jul 18, 2008 | 07:00 PM
  #76
hungryhip-ccp's Avatar
Originally Posted by ikeryder13
so was this almost all bolt on hip?
yep.
Originally Posted by invisible
Wow, you're supercharger is so clean. lol
i keep my whole engine bay/car that clean
Last edited by hungryhip-ccp; Jul 18, 2008 at 07:00 PM. Reason: Automerged Doublepost
Old Jul 18, 2008 | 07:21 PM
  #77
Mr_Slobalt's Avatar
nice install
I think you have me sold on this one
Old Jul 18, 2008 | 07:31 PM
  #78
Kibosh3's Avatar
mhmmm...i want as well...but dont have enough for this and hptuners...so
Old Jul 21, 2008 | 05:42 AM
  #79
Originally Posted by csementuh
Getting the post back on track concerning the install of a heat exchanger... I decided to make a new diagram for the LSJ Intercooler System Plumbing with Dual Pass Endplate and Secondary Heat Exchanger.
Everyone seems to never want to route the hot coolant through the IC Pump in their diagrams, however this is how GM tells you to do it when installing their Dual Pass. This is the routing I have with my setup using a ZZP Dual Pass End Plate (No Option B) and a CX Racing H/E. Please discuss...
thats how i have mine, just minus the stock h/e im only running the cx racing h/e...
Old Jul 21, 2008 | 12:27 PM
  #80
csementuh's Avatar
Sounds good man, I'm glad somebody actually looked at my crazy MS Paint diagram, haha That is how my setup will be whenever I receive my CX Racing H/E in the mail today. I can't wait! Thanks for the awesome writeup!
Old Jul 21, 2008 | 01:15 PM
  #81
methodman2424's Avatar
I can't find the smaller heat exchanger anywhere on ebay or anything. Need to buy it.
Old Jul 21, 2008 | 01:59 PM
  #82
Tazmanian_Dvl's Avatar
I'll find you the link...hang on...
Edit...
Here's the link...
http://cgi.ebay.com/ebaymotors/Alumi...3911.m14.l1318
Old Jul 21, 2008 | 02:48 PM
  #83
Somebody bought it...all they have is the bigger ones listed now.
Old Jul 21, 2008 | 03:27 PM
  #84
Bika's Avatar
Fail Less.
http://cgi.ebay.com/ebaymotors/Alumi...mZ370069199678
heres one.
or just go to the seller's store. he's always selling atleast one of the small cx h/e
Old Jul 21, 2008 | 09:13 PM
  #85
please don buy the bigger 1, can we say OVERKILL
Old Jul 22, 2008 | 07:45 PM
  #86
csementuh's Avatar
I have a question for any of you guys that have a HE installed..?
I just finished installing my CX Racing H/E, same one as the OP's. I hooked up all the lines and took off the CXR HE bleeder. I filled the top fill cap with coolant/water until it overflowed on the HE and then put the bleeder back in. I then put more liquid into the funnel in the fill cap and started the car. A bit of the coolant was sucked down into the tube and I kept the liquid nice and full in the fill cap tube. The water bubbled a little bit. I left the engine run like this for a few minutes. When I saw no more bubbling or activity I took out the funnel and capped off the fill tube...
I left the car sit and idle in my driveway for about 15 minutes while I cleaned my garage up. I checked the fill tube again and it had a healthy amount of liquid. I got in the car to take it for a test ride and noticed the engine temp was 214 degrees F. This is the hottest I have ever seen it. The highest I ever saw before was about 204. The ambient temp was 85 F. I started driving the car and the temp cooled down to about 185F which is normal for my car. It cooled down within about 3 minutes...
My question? Is this normal? Do you think there was still some air trapped in the system? I DO NOT have option B. I know to check the fill tube and refill as needed till all air is purged. Is there any way I can make sure that the flow is working good? I don't have an Interceptor or HP Tuners so I can't monitor IAT 1 & 2. The fluid "moves" inside the bottom of the fill tube so I believe it to be pumping. Anyone have any ideas / comments / suggestions? Am I just being paranoid? Thanks!
Old Jul 22, 2008 | 09:50 PM
  #87
Bika's Avatar
Fail Less.
15 min is a long time to be idling.
this heat exchanger has nothing to do with your engine coolant. completely separate cooling system. your car is just fine.
Old Jul 22, 2008 | 11:44 PM
  #88
csementuh's Avatar
Thanks for the reply. I understand that the systems are totally separate but I figured that increased IAT's would heat up the engine substancially. I will drive it for a couple days and see how it goes...
Old Jul 23, 2008 | 02:41 PM
  #89
Zach06CobaltSC's Avatar
I am sure it will be fine mate. The iat1 and iat2s are whats important with the heat exchanger. More so the iat2's then anything. I really recommend that you get an interceptor or hptuners so you can log some of your data. Thats part of the fun, doing a few hard pulls with no mods and seeing sky high numbers and watching them drop as you do mods. =D lets you know your doing things right.
ineedacobaltss
Nov 7, 2015 02:25 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Sep 27, 2015 08:53 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
