Demonic Cobalt
Old Dec 14, 2010 | 07:04 PM
Legion's Avatar
Demonic Cobalt
Alright I'm setting up to start my 350 DD pull. Alot of the items will be a mix between ZZP, Stillen, Clutchmaster, Hurst, and Eibach parts mixed with the goodies kits and common sense says drag in. I'm getting a ZZP STG 3 w/ STG 3 Intercooler, 2.8 Pull, 80lbs soon, and after taxes come back the exhaust will be in. An engine/valvetrain is set for this July pending my ladies approval and I'm not moving to Japan. See signature for current parts listing if you wonder, it is retuned and in good shape for stockish grade tuning. I'm getting a Clutch and Flywheel installed with driveline upgrades prior to these moves, alittle after the exhaust.
Issue I'm having is does anyone have recommendations in these areas as I go...
Brakes Stage:
Planning on Stillen Rotors/Pads w/stainless lines.
Suspension Stage:
ZZP hard parts to reinforce traction where the Eibach kit is incomplete.
Boost Stage:
TVS, LS4 TB, NO2/CO2 Sprays WET inside/ Dry outside, Pulley's Swapped to Lightweight.
Exhaust Stage:
3in Header Back ZZP system w/ cat and mag resonators but flowing into 3in DC Can 4in tip matted black.
Suggestions Recommendations for me when I take the plunge? I've built a pretty successful Mustang, so I'd say my tune sense is about medium, able to make mistakes, but knows what the parts are when I see em. I get dirty when I can, but I do not handle suspension, or valve work stuff, essentially use a shop whenever it's beyound my understanding or capability within reason.
Old Dec 14, 2010 | 07:21 PM
selfinfliction's Avatar
why add a tvs if you're adding nitrous? that pretty much makes the supercharger irrelevant with enough of it
Old Dec 15, 2010 | 04:19 PM
Legion's Avatar
NO2 is a assistant nothing more...
Old Dec 15, 2010 | 04:28 PM
Dart_SI's Avatar
stillen? isnt that a nissan only brand?
Old Dec 15, 2010 | 04:35 PM
Legion's Avatar
It's more like Jegs... Except way better brand for their stuff see they're brakes highly recommended...
chefhhr
Oct 26, 2015 10:36 PM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
Bluelightning
Sep 8, 2015 05:18 PM
jthwjde
Sep 7, 2015 09:24 AM
