Diagnostic Scan tool
Old Feb 26, 2006 | 09:20 PM
Nauticabri's Avatar
I have a question about where and if I can get a diagnostic scan tool for our Cobalt SS supercharged. Something that is good a vehicle specific that will tell me what some of these damn codes we spit are for (CEL for intake) without having to strip everything back down to stock and take in to the dealership, preferably one that can clear codes as well Anybody know of anything?
Old Feb 26, 2006 | 09:54 PM
ENUFPWR's Avatar
Aeroforce Tech Scan Guage.... available from most vendors here on this site.
http://www.aeroforcetech.com/
Old Feb 26, 2006 | 10:49 PM
SilverSS/SC's Avatar
Dont leave home without it .
btw , thanks for the mounting idea Daren . Sometimes the simplest ideas are slapping u in the face
Old Feb 26, 2006 | 10:53 PM
djt81185's Avatar
Look like 6 threads down or should be 1 thread below now lol
Dan
Old Feb 26, 2006 | 11:01 PM
FAST06SS's Avatar
The cobalt is a CAN pcm. You can get basic data with a generic reader but to access all data you will need a can interface. I just checked the data lines into the pcm from gm servive manuals, there is 2 lines, High speed data hi + and high speed data Low -
Old Feb 27, 2006 | 12:01 AM
WopOnTour's Avatar
Not quite.Just because it's connected to the HS GMLan doesnt mean it's utilized or absolutely neccessary for scan tool diagnostic functions or even for service programming flash routines for that matter.
Yes, the LSJ's P12 PCM IS connected to the HS GMLan (DWCAN) but functions with it in a somewhat limited fashion.
(compared to the 2.2/2.4L engines for instance.)
There ARE some PCM I/O functions that rely on the CAN interface such as instrumentation outputs (ECT and VSS to the IPC/DIC for example) and items such as Theft Deterrant Fuel Enable but these are essentially just "gatewayed" between the HS GMLan and Low Speed GMLan (SWCAN) by the Body Ccontrol Module (which resides on BOTH networks)
In a nutshell a CAN capable scan tool interface is NOT required for almost all LSJ scan tool powertrain functions.
If the LSJ box was primarily a CAN ECU your Aeroforce couldnt even function on the Cobalt as it connects to the OBD2 Class 2 bus (J1850 VPW) exclusively.
HTH
WopOnTour
Old Feb 27, 2006 | 11:37 AM
2K2CamaroSS's Avatar
I use HP-Tuners, being as I already own it. Just too damn bad there's no support to tune this LSJ with it.
Old Feb 27, 2006 | 11:52 AM
R33P3R007's Avatar
360 L337 User
what they said ^^ http://www.aeroforcetech.com/
Oct 20, 2015 09:56 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
DocSvensk
Sep 27, 2015 02:24 PM
