Difference between 2.0 and 2.2
Old Sep 11, 2009 | 10:55 AM
CobaltSS313's Avatar
Can someone link me the specs forthe 2.0 and 2.2 engines. I just wanna see what the difference between them, whether its the stroke or the bore. I dont think the crank is different. If anyone can lead me in the right direction I'd appreciate it, thanks.
Old Sep 11, 2009 | 11:00 AM
OneCOLDBIZL272's Avatar
lsj is 86mm bore 86mm stroke compression 9.5:1, 2.2 is 86mm bore with 94.6mm stroke compression 10.0:1 i think
Old Sep 11, 2009 | 11:02 AM
so r the rods are longer and the crank is the same?
Old Sep 11, 2009 | 11:27 AM
i dont know if the rods are longer or if the piston height is different or both. ask hunterkiller he would know
Old Sep 11, 2009 | 12:16 PM
383_Stroker's Avatar
Stoke is referring to the crank.. rod length does not effect the "stroke" measurement
Old Sep 11, 2009 | 12:48 PM
So the crank is different then. I'm pretty sure a 2.2 motor will bolt into a SS though if
I'm not mistaken.
Old Sep 11, 2009 | 05:02 PM
HunterKiller89's Avatar
there are a decent number of differences. also, there are numerous 2.2 engines and a couple 2.0 engies to choose from in this comparison.
whats your goal? itll probably be easier to answer that than to list all the differences for you.
Old Sep 11, 2009 | 05:09 PM
06SS ALL DAY's Avatar
the 2.0 is faster than the 2.2 stock vs stock. however the 2.2 holds the record in the 1/4 so im told
Old Sep 11, 2009 | 05:11 PM
WSFrazier's Avatar
If you're trying to do a stroker, you will can use your current block, but you will need a 2.2 rotating assembly. Eagle/oe gm crank, eagle rods, wiseco pistons, IMO.
However, the cranks have different reluctor rings and flywheel bolt patterns. So some work will be needed.
No ****, the 2.0 has a supercharger strapped to it genius.
Old Sep 11, 2009 | 05:20 PM
EXsoccer1921's Avatar
http://www.gmtunersource.com/media/r...mplete-web.pdf
start on page 85.
Old Sep 11, 2009 | 05:51 PM
dood ur lying an LSJunior does not have a blower on it
Old Sep 11, 2009 | 11:08 PM
Witt's Avatar
Rofl. I love this forum.
Old Jul 31, 2018 | 01:16 PM
Hot Cobalt1's Avatar
I rebuild my 07 cobalt motor but the 2.0 block was bad. So I used a 2.0 rebuild kit in a 2.2 block with no problems or any mods having to but done. the only difference was one water port on the 2.2 was a hair smaller than the 2.0..
SuperSport4
Jan 6, 2010 02:14 PM
boosted2.2
Aug 18, 2009 11:47 PM
memphisr24
Aug 1, 2008 11:21 PM
woble777
Jul 22, 2008 10:18 PM
diablo2007
Nov 13, 2006 06:38 PM
