Direct Port Injection for Meth?
Old May 26, 2008 | 12:44 AM
XCRuna1201's Avatar
Question Direct Port Injection for Meth?
Okay so I just bought a CXRacing H/E from ottperformance (they have all the brackets,hoses, and clamps in the kit so you dont ahve to make them!) And as I was browsing their website I came across an upgrade of meth injection to Direct Port Injection....how does that work? I am getting meth next and wanted to know if this was a more efficient way of spraying the meth and how its done. Thanks!
Old May 26, 2008 | 09:11 AM
selfinfliction's Avatar
waste of money. if you're going to do direct injection, you might as well be using nitrous to get the real benefits.
Old May 26, 2008 | 10:24 AM
Tennpenn83's Avatar
If you already have meth.. maybe. But methanol/water injection is better used to cool down the air intake temperatures, not to mention the supercharger itself, and the laminova coils and the intake manifold. I agree with above poster, direct port would suit better for nitrous.
Old May 26, 2008 | 10:27 AM
widebody_balt_ss's Avatar
I agree.^^ use the meth injection preblower to help with intake temps. at least thats what I will me doing if the day ever comes for me to ever use mine!
Old May 26, 2008 | 10:37 AM
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Go with pre-blower and place the nozzle before the throttle. If you have any other questions feel free to email me directly at rodney@alcoholinjectionsystems.com
Old May 26, 2008 | 11:06 AM
trust this guy! He will help you out!
Old May 26, 2008 | 12:44 PM
XCRuna1201's Avatar
well what is the best way to go about spraying the meth?
Old May 26, 2008 | 01:24 PM
ralliartist's Avatar
I will be doing this when I get back. Check my cooling mods thread. I put it in there. I'm pretty sure direct injection meth will provide better gains than just spraying before the throttle body. You got to be precise with it though. I plan on spraying 4 50cc injectors in the intake runners and 1 90cc injector into the throttle body.
Old May 26, 2008 | 04:02 PM
XCRuna1201's Avatar
so I guess if I want to I can do the direct injection later on after I go ahead and have the normal meth set up threw the intake....sounds good
Old May 26, 2008 | 06:31 PM
Tennpenn83's Avatar
There is a plate being made currently that allows for right after the throttle body... is there a big difference between being right before or right after if both are before the supercharger?
here is the link :
https://www.cobaltss.net/forums/parts-66/gauging-interest-tb-spacer-111345/
Old May 26, 2008 | 06:44 PM
ecotecon18s's Avatar
here is the link :
https://www.cobaltss.net/forums/showthread.php?t=111345
yeah, spray before and it will clean the thottle body blade off for you
Old May 27, 2008 | 12:32 AM
Tennpenn83's Avatar
good point...
Old Jun 2, 2008 | 01:36 PM
AIS's Avatar
AIS
good point...
We've had a quite a few customer buy the plates and use them which is fine. You can use a plate. However, the end result is the same. There's no advantage to using a plate other then the added cost.
Old Jun 2, 2008 | 03:26 PM
Saltbager's Avatar
using a plate is slightly more convenient in my eyes ....
Old Jun 6, 2008 | 09:20 AM
AIS's Avatar
AIS
You can use a plate if you don't mind spending an additional $60-$90.00 for the spacer and shipping. However, the end result is the same. The point is there is no performance advantage to using a plate vs having the nozzle located before the throttle body in the cold air.
We looked into making spacers and didn't see much added value for the customer for the additional cost they would have to pay for the plate. It's quite simple to remove the cold air system. Buy a $6.00 tap and drill and tap it yourself. It's really
Rodney
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
