Direct port meth injection
Old Jun 1, 2011 | 06:03 AM
87gn06gto07irl's Avatar
Seems like everyone either taps into the intake, uses a t/b spacer, or uses a s/c spacer. I'm going to go the direct injection route. Makes sense to me to get an even amount into each cylinder. I would like to know the pros, cons, and tips from the people that have used this set up. Pics would be nice too.
Old Jun 1, 2011 | 12:58 PM
ebristol's Avatar
I have never done it but I have something that would make the job easy.
Just remove the injectors and insert your meth nozzles.
Old Jun 1, 2011 | 02:49 PM
Bluelightning's Avatar
Got Bewst?
My buddy Kennyspec did it on his LSJ turbo swap...
https://www.cobaltss.net/forums/adva...not-me-230343/
Old Jun 1, 2011 | 03:28 PM
HHRSSouth's Avatar
^^^What Methanol mix was your buddy running?
Because you can have the same thing happen with a single port meth set up.
Down side of a single port set up is the mixture doesn't get distriputed evenly to all cylinders and if that one nozzle stops working say bye bye to all 4 pistons, not just 1.
I'm going to be ordering a Devils own Direct port setup within the next 2 weeks.
Although I will be ordering the upgrade kit with the port block and electronic solenoid upgrade to go along with it.
Old Jun 1, 2011 | 05:22 PM
Got Bewst?
He was running just washer fluid. As far as I know the reason it went down is because just 1 nozzle was plugged and knock on that 1 cylinder wasn't showing up on his interceptor
Old Jun 2, 2011 | 02:10 PM
ebristol's Avatar
Washer fluid can have many mixes of methanol. It can be as low as < 1% up to almost 40% depending on the brand.
Old Jun 2, 2011 | 05:01 PM
Frew's Avatar
Me personally would never run meth on the street again, too many issues even with a sound setup. But that's just me
Old Jun 7, 2011 | 06:07 AM
You getting rid if that bad boy? If not, what did it come off of if it wasn't custom made?
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
