Does a scantool detect a disabled rear oxygen sensor?
Old Feb 19, 2008 | 07:34 PM
MTchevy1's Avatar
I'm putting on a catless downpipe, and I'm going to disable my rear sensor with HPtuners. I'm wondering if they'll detect it when I go to the emissions test and they scan my car. Anyone know?
Old Feb 19, 2008 | 07:35 PM
madmark's Avatar
i think it will read 400 which means it isnt working or connected
Old Feb 19, 2008 | 07:38 PM
MTchevy1's Avatar
Damn, that was a fast reply! So what do all the people running catless do about emissions testing? Put the cat back on? Do the spark plug anti foulers actually work?
Old Feb 19, 2008 | 07:41 PM
Frankruffolo257's Avatar
ive had the anti fowlers work before on my buick regal GS. you may need to double stack them though
Old Feb 19, 2008 | 08:01 PM
SSdan's Avatar
They don't work on the cobalt. Not enough room for them to fit without cutting part of the car up.
Old Feb 19, 2008 | 08:45 PM
madmark's Avatar
you mean o2 simulators or o2 spacers?
they work fine pm hockeyman0920 and he can tell you where he got them
Old Feb 19, 2008 | 09:38 PM
Rodimus_Prime's Avatar
if they are turned off in hp tuners they wont
Old Feb 19, 2008 | 09:49 PM
Sharkey's Avatar
if they are turned off the code wont set. basicly when you go through the emmissions test they look at whats called global generic OBDII, wich shows them any emmissions related codes, system moniters and will show a code if there is a code in a system (such as p0700- fault in trans controller). all they are going to look at is to see that any moniters that are supposed to be set are and that you have no codes.
Old Feb 19, 2008 | 10:15 PM
elecblue06's Avatar
hmm good to know
Old Feb 19, 2008 | 10:23 PM
SSdan's Avatar
I tried, they physically will not fit in the exhaust channel with the o2 sensor.
Old Feb 20, 2008 | 12:09 AM
Blur.fx's Avatar
Pave It All...
Would a right angle fitting help out with the lack of space?
http://weapon-r.com/...&product_id=6219
Old Feb 20, 2008 | 08:15 AM
SSdan's Avatar
I don't see why it wouldn't.
Old Feb 20, 2008 | 08:18 AM
EdCobaltSS's Avatar
they search for codes ONLY, it will not pick up wether you have disabled it or not, you should have 0 problems!! (Certified Massachusetts State Vehicle Inspector)
Old Feb 20, 2008 | 08:31 AM
Gabi's Avatar
this is good to know
Old Feb 20, 2008 | 05:08 PM
MTchevy1's Avatar
Thanks for the info guys!
Old Feb 20, 2008 | 05:21 PM
EdCobaltSS's Avatar
no problem
Old Feb 20, 2008 | 06:13 PM
06blackSC's Avatar
I agree. (fellow MA licensed inspector here) the emissions plug in will detect a possible fault code (if there is any in history) but as long and the check engine light is not illuminated, there shouldn't be an issue. I have had cars that fail in one or two of the categories that are scanned for inspection but since they did not have a check engine light on, they passed with flying colors.
When i get my catless DP, I'll get the rear O2 disabled and plug my car into the inspection machine at work. I will give you guys a definitive answer when i get the parts and tuning.
Old Feb 20, 2008 | 07:02 PM
EdCobaltSS's Avatar
keep the S license workin bro!!! LOL
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
jmelton327
Sep 26, 2015 10:04 PM
