downpipe hlep maybe a header too
Old Mar 25, 2009 | 08:40 PM
craigk_c19's Avatar
ok when i got back from spring break my car sounded like total crap so i figured it might be an exhaust so i crawled under and this is what i found and i was going to replace both the header and the down pipe someday but now looks like i get to do that sooner then i thought can i just replace the downpipe or replace both header and downpipe if so what are good to get? i did see that cobalt addiction had a good deal going on it that worth it? im a noobie with headers and downpipes so all information would be greatly appricated thanks again guys and hopely my car wont sound like a sick dog fixing to die for much longer
Old Mar 25, 2009 | 08:42 PM
Jared B's Avatar
ZZP shorty headers and downpipe
Black SS/SC 06's Avatar
Broken flexpipe. You just need to replace it or get an aftermarket downpipe. I have the CTI and like it.
Old Mar 25, 2009 | 08:45 PM
craigk_c19's Avatar
you can just replace the flexpipe can you?
Old Mar 25, 2009 | 08:46 PM
Yea you can get a new one welded on. Probably the cheapest route depending on where you get it done. I would probably just get an aftermarket downpipe with a high flow cat. Your cat probably will go next anyways lol.
craigk_c19's Avatar
from what ive been seening on my searching the mid length header is the best bang for the buck
Old Mar 25, 2009 | 10:34 PM
ClearImageAuto Dan's Avatar
A local exhaust shop should be able to cut the stock flex section out and replace it with a new one. That would be the least expensive way to go. If they can not find one, we do offer them separately.
Next would be to replace the down-pipe. We offer a stock replacement.
or go with a mid-length header and down-pipe.
here's our header:
Give us a call if we can help: (425)251-0329.
Good luck with everything.
Old Mar 25, 2009 | 10:42 PM
philipino guy's Avatar
if you don't want to spend money chevy will replace that downpipe for free under warranty that downpipe is covered up to 80,000 miles i believe. i just got mine done this past winter might as well get a new one from the dealer.
Old Mar 25, 2009 | 10:54 PM
craigk_c19's Avatar
im really debating with my self if i should just go ahead and get a header and downpipe i have always planed on getting them just gives me an excuse to do it earlier so i might just go ahead and replace them and the viberant hearder and down pipe are on sale with TTR right now and im really thinking i should do that what do you think?
Old Mar 26, 2009 | 05:59 AM
get a new downpipe from g.m under warranty that way you have a new one to keep or sell later and still get your aftermarket header and downpipe too. i'd rather have a new downpipe sitting around instead of a broke one that way if you want to sell it later you'll have no problem of getting rid of it. just my 2 cents on the whole thing.
Old Mar 26, 2009 | 08:16 AM
pecorillif's Avatar
same thing happened here, except the hole in mine is about 10 times bigger, i just ended up getting the cti header and dp with the OTT 3" stainless exhaust. installing it in about 5 min actually
Old Mar 26, 2009 | 08:37 AM
TurboTechRacing's Avatar
A good fix to those who do not want an aftermarket downpipe would be to get TTR's upper engine mount and poly bushings... They crack because the engine moves a lot. Poly's will stop this...
Old Mar 26, 2009 | 08:50 AM
qwikredline's Avatar
they break . If you want a really really cheap solution i can sell you a new stock oem flex with plate and a short 7 inch run of tube flared to fit onto stock tubing for repair, 30 bucks ... OTTP mounts will stop the issue its hop that does it mostly..clear image do a nice header if you want to spend the bucks and get rid of the oem flex...
Old Mar 26, 2009 | 11:48 AM
craigk_c19's Avatar
well i have already talked my self into getting a new header and downpipe i just need some options now i see that TTR has a deal on the vibrant header and downpipe what do yall think should i get it? and im already getting a OTTP h/e and dual endplate
Old Mar 26, 2009 | 11:49 AM
ShortStack's Avatar
Clear Image.. Dont spend the extra money on a vibrant.
Old Mar 26, 2009 | 11:51 AM
umrdyldo's Avatar
Isn't the vibrant pretty high. I'd either go with clear image or with the ZZP combo.
https://www.zzperformance.com/cobalt...=545&catid=155
Get it with high flow cat and in stainless steel
Old Mar 26, 2009 | 11:53 AM
ShortStack's Avatar
Your going to spend wayy too much on the vibrant...
Clear image stuff is awesome, i loved it.
Old Mar 26, 2009 | 12:21 PM
craigk_c19's Avatar
the zzp one is 500 after you make everything stainless
i just got done look at all my options and the CI header and downpipe would be more $$ then the vibrant combo and the zzp is only 80 bucks less then the vibrant so looks like ill be spending at least 500 im really wanting the stainless steal one no matter who i go with so what should i get? i plan on getting 1 3/4" primary tubes a catless downpipe and i want a 3'' downpipe with a 2.5 exit since i have a magna flow catback system now i need inputs and the vibrant downpipe is only in 2.5 i think
Last edited by craigk_c19; Mar 26, 2009 at 12:23 PM. Reason: Automerged Doublepost
Old Mar 26, 2009 | 12:22 PM
Dainslaif's Avatar
+1 Clear Image. I have their 3" header / catless DP / catback exhaust and it sounds amazing. Friends I've rode with have commented how clean it sounds compared to other exhausts they've heard (Vibrant / GMPP).
I think Dan is still trying to push some of the Stainless 1.75->3" header/DP combos on here, look in the group buy section. It is a little more expensive than some others but it's VERY worth it. ZZP you have to worry about flange leaks, I haven't had a single problem with mine.
Old Mar 26, 2009 | 12:24 PM
craigk_c19's Avatar
i already have magnaflow exhaust im talking about a header and downpipe combo sounds good tho!!
Old Mar 26, 2009 | 12:30 PM
ShortStack's Avatar
Well.. for what its worth...
Its not stainless, but i have my clear image 1.75 header, 3" dp to 2.5 exit for sale.
Old Mar 26, 2009 | 12:32 PM
craigk_c19's Avatar
why you getting rid of it?
Old Mar 26, 2009 | 12:34 PM
Dainslaif's Avatar
Guessing by his sig he went turbo, needed a turbo exhaust manifold so had to drop the header/DP.
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
