drivetrain winding noise
Old Feb 15, 2010 | 10:15 PM
tmharsh's Avatar
I dealt with a bad bearing recently and it basically sounded like those big noisy truck tires. Generally started to hear it once I got up around 40. Wiggling the tire didn't show any excessive play. I also don't recall hearing it quiet down when turning in a particular direction until it became much louder. It was very apparent that it was quieting down when turning one way by quickly swerving back and forth, which would produce a distinct break in the noise.
This LSJ build book chapter goes through a clutch install and the removal and install of the hub assembly is covered -> http://www.gmtunersource.com/media/r...LSJ_Chap_5.pdf
According to this, the three hub bolts are 85 ft/lb and the axle nut is 155 ft/lb.
Also, when you go to buy a bearing, it's best to avoid the cheaper off-brands at the chain stores. Timken, National, and SKF are good brands. You'll also find them cheaper online, but watch out for super cheap ebay deals and such because some counterfeits are out there. I've always found Rock Auto to be a reliable online store with lower prices.
Old Feb 15, 2010 | 10:41 PM
miked5426's Avatar
Once again.. my sound doesnt change wen turning the wheel...fast or slow. The sound is more distinct at 70-80 mph. Its so wierd....
Old Feb 16, 2010 | 09:02 AM
tmharsh's Avatar
Like I said, I didn't notice the sound changing while turning until it got bad. It had to be loud enough to drown out the normal road noise and be audible with the radio on before I could tell it was getting quiet when turning in a particular direction. Starts as a low hum and progressively works it's way up to sounding like low-flying plane at highway speed. Look on youtube, I believe people have posted videos of what a bad wheel bearing sounds like. You described it as a winding noise, so if it's more of a high-pitched sound, it may be something else.
Old Feb 16, 2010 | 04:56 PM
miked5426's Avatar
Ya. Sounds like an airplane! We will see. Its gota be the pro.blem!
Old Feb 16, 2010 | 09:12 PM
tmharsh's Avatar
You'll also have to pinpoint which wheel it is if it's a bad wheel bearing. I could easily tell which one was bad and quickly swerving confirmed it. But, I'm not sure if a bad bearing in the rear gets quieter when you turn, it may not load the bearing like it does in the front.
Old Feb 16, 2010 | 09:29 PM
miked5426's Avatar
IT appears to b my front ones. Ill jus waot longer to see if itll give me more clues
Old Feb 16, 2010 | 09:46 PM
PerformanceClutches's Avatar
if your at 80mph and you put the car in 4th gear or maybe even have it in 5th (wouldn't be as loud). and let of the gas completely at a high speed and have the car in gear but your foot isn't on the gas do you hear the noise? it sounds like a transmission noise whine? now put your foot down on the clutch does the noise go away? or take it out of gear and coast do you still hear the noise? now notice if you have the car in gear at 80mph in 4th gear and completely let off the gas and coast do you hear the whine or sounds like chains or something banging around? now slightly give the car gas it should be at like -22 -25 in vacuum on the boost gauge and make it read like -10 in vacuum or even 0psi. do you hear the noise then?
basically do you hear the noise only when you let off the gas completely and it is in gear higher rpm's? if so i think it might be your transmission. i am having the same problem and had the problem for the past 10k miles and it's been driving me nuts. not sure what it is. have a friend who works at a trans show and told me it's something inside the trans.
please let me know if this is the problem your having
Old Feb 16, 2010 | 09:58 PM
miked5426's Avatar
The sound quiets wen i take it outa gear. It seems to b trany. It dont go away nut it quiets considerably once i put it n neutral
Old Feb 17, 2010 | 01:53 AM
so it's the transmission? you and i have the same problem. I am scared to take it to a trans place and see how much it cost to fix.
Old Feb 17, 2010 | 10:35 AM
miked5426's Avatar
Could itb something with flywheel or clutch?
Old Feb 17, 2010 | 10:38 AM
  #36
advise's Avatar
i got a spare hub just sitting if ya need it
https://www.cobaltss.net/forums/parts-66/stock-parts-brake-pads-new-sensors-202781/
Old Feb 17, 2010 | 11:18 AM
  #37
blackbolt89's Avatar
I thot they make grinding noise wen bad?
they only start grinding when they're FUBAR.
i had a wheel bearing go on my 160k mile explorer and when we took it apart i was amazed that the wheel still spun. lol.
Old Feb 17, 2010 | 12:04 PM
  #38
don't think so. i replaced my clutch and got my stock flywheel resurfaced. if your having the same problem as me i am pretty sure its the trans. if u end up fixing it let me know how much it cost and what was wrong with the trans.
Old Feb 17, 2010 | 12:23 PM
  #39
miked5426's Avatar
NAW i aint fixn it. I dnt even wana no price lol
Old Feb 17, 2010 | 12:30 PM
  #40
miked5426's Avatar
What bout the jerk i get around 35-40 mph wen deaccelerating. Sumone mentiond sum5hin bout it being the gear ratio changing over. Its a pretty bad jerk sumtimes. Any idea?
  #41
tmharsh's Avatar
If you suspect it's the gearbox, perhaps try changing the fluid and seeing if that helps. Have you ever done that or do you have over 150,000 miles on the factory fill?
Old Feb 17, 2010 | 01:40 PM
  #42
miked5426's Avatar
U TALKIN bout the 85-90 fluid or sumthin. Its been changd once with royal purple
Old Feb 17, 2010 | 01:50 PM
  #43
EXsoccer1921's Avatar
gremlins swapped in a straightcut gear set while you were sleeping. take it with respect. or they'll be offended
Old Feb 17, 2010 | 02:51 PM
  #44
miked5426's Avatar
not funny. I need answers!
Old Feb 17, 2010 | 09:24 PM
  #45
miked5426's Avatar
Went to a trany shop n they think the bearing sound is coming from. the throwout bearibg. He saud it could becoming unseated since i have 158+k miles on it.
Also, wen i engage my clutch from a stop it, the clutch itself, makes alota cluttering noise....suggesting that, even though it grabs good, its prolly time to geta new clutch. Any thots?
Old Feb 18, 2010 | 10:38 AM
  #46
rnjmur's Avatar
The jerking at 35-40 mph is due to DFCO (Deacceleration Fuel Cut Off).
Old Feb 18, 2010 | 10:58 AM
  #47
JapEatr's Avatar
South Central *********
same noise...only when i am decelerating, the clutch depressed doesnt fully make the sound go away
Above 50 MPH and slowing down to about 30 does it every time
Old Feb 18, 2010 | 01:28 PM
  #48
miked5426's Avatar
how old is ur clutch?
Old Feb 21, 2010 | 10:55 PM
  #49
miked5426's Avatar
thats not true. I know what DFCO is and this is a completely different jerk. Besides, DFCO isnt going to change unless the tune does..and this jerking has begun recently and gotten worse.
Its the same pulse you feel when your accelerating, which is what I was told something about the gear ratio changing over. Idk the truth. but im worried about this jerk,
Old Jun 14, 2011 | 11:01 AM
  #50
organic E's Avatar
what fluid are you using in your trans. I am having this problem as well. basically in drive straight and decel, sounds like straight cut gears. Please UPDATE thanks.
