Dual End Plate & Option B Install Help - Pictures
I want to double check my dual pass/option B install before starting the car as it is hard to tell with some of the diagrams available.
My main question is do I route the out piping from dual pass endplate to the IC pump's hose from the top of the unit or the side? The diagram below shows the IC pump inflow to be the top and outflow from the side but my side pipe has always been hooked up to the radiator shroud and i am assuming that connects to the intercooler.
Also, does the end plate's center inlet route to the bottom right of the radiator shroud?
Pictures:
Blue is the outflow, Red in the inflow to dual pass endplate.
Does this install look correct to you?
Thank you for your help.
Instructions:
Pictures:
Instructions:
Seems to be right, I just installed mine and followed the ZZP Dual pass diagram to hook it up.
Your output from intake laminova should be on top and bottom and middle two should be input if you did it correct (had to swap bottom two cores).
Just do a search there are some how to diagrams some where around here
I got everything routed correctly as per the diagram above and I am now running into some problems with drive ability.
After the car warms up and when I drove it on the freeway the motor was way down on power. Boost would build but I had to keep the pedal down quite far to keep the car at speed on the highway. So i immediately stopped driving.
I checked the IC pump and it was not working. Would this cause the car to dramatically lose most of the power because no coolant was flowing through the system and the car was taking in hot air? The steering wheel was shaking too not sure why maybe from the engine. I don't have any alignment or wheels/tire issues.
No check engine lights have come on.
Additionally, the option b tank had the hose leading to the end plate routed wrong where the highest point in the system was the hose not the tank, so I re-routed that.
Any advice on what could have gone wrong? I think I just had a lot of air in the IC system and a broken pump but the engine sure did lose a lot of power.
No coolant smell in the exhaust I think the end plate is fine.
Thanks for the help again.
I suggest replaceing your IC Pump.
The dealership will want 550 Bux for one,
ZZP wants about 110, and OTTP wants
slightly less then ZZP last I checked. Yes having an inop IC pump can cause you to loose power because of high intake temps.
First make sure its plugged in good though. No need to spend 100 bux if you just forgot to plug it in.
& Check the fuse
Stock system plus secondary heat exchanger:
Out pump>stock heat exchanger in/out>secondary heat exchanger in/out>end plate> filler neck> pump
Picture above:
Out pump>stock heat exchanger in/out> secondary heat exchanger in/out> middle nipple on dual pass end plate>out dual nipples on dual pass end plate> filler neck (Option B replaces filler neck)>pump
Someone correct me if thats wrong, did this last year but I think its right.
Picture above:
https://www.cobaltss.net/forums/how-...rnator-274630/
^I didnt make this thread for nothing guys....
Everything you will need for the install is found in my thread.
