dual heat exchangers. and josh from ott.
Old Jan 17, 2009 | 04:20 AM
wtpcobaltss's Avatar
Ok so ive been running just the cx heat exchanger for about 5 months and decided since i got the ott stage 1 on the way that maybe more cooling would be a great idea... so im using both the filler neck runs into the stock then out to the cx then into the pump. will this be ok or would it have been best just to use the cx??? by the way does anyone know josh from ott becausse my cpu messed up and its shows me buying the ott stage 1 3x's i dont need 3 and i need my 1400 dollars.
Old Jan 17, 2009 | 04:25 AM
Wolf117's Avatar
isnt josh fast98 or something?
Old Jan 17, 2009 | 04:26 AM
EXsoccer1921's Avatar
yes, it will be fine. it is actually prefered that you run the cx inline with the factory h/e
yes again
Last edited by EXsoccer1921; Jan 17, 2009 at 04:26 AM. Reason: Automerged Doublepost
Old Jan 17, 2009 | 06:49 AM
qwikredline's Avatar
talk to Josh he will resolve your issues, and go to Option B dont waste time with the silly stock T filler it really is junque....good luck
Old Jan 17, 2009 | 08:14 AM
coopn8r's Avatar
I'm sure if you paid 3 Times you'll get a prompt refund! :P They are good people.
Old Jan 17, 2009 | 10:40 AM
lsjwannabe's Avatar
Your all good brandon, only one order went through
Old Jan 17, 2009 | 05:01 PM
krazycobalt's Avatar
I am running the OTT heat exchanger and the stock one!!! love it too
Old Jan 20, 2009 | 02:49 AM
tdipowered's Avatar
make him pay!!!!! just kidding i have the old design h/e from OTT and I WUV it!!!
Old Jan 20, 2009 | 09:39 AM
flash13brandon's Avatar
I hope this doesn't turn into the epic 1 h/e vs 2 lol...by the way, 1 h/e FTW
Old Jan 20, 2009 | 10:16 AM
ShortStack's Avatar
Why?
More coolant, better cooling..
Didnt you just have a problem with installing them inline?
Old Jan 20, 2009 | 10:29 AM
Originally Posted by ShortStack
Why?
....I never tried to install them inline...Hungryhip did a test and found that cooling was better with just one, I don't think there is much of a difference because the stock one does not hold that much anyways.
Old Jan 20, 2009 | 10:36 AM
ShortStack's Avatar
I was just messin man haha...
Really? yea i guess it does seem really small.. Ill have to look up those tests.
Old Jan 20, 2009 | 10:41 AM
invisible's Avatar
It still runs through both of them so it gets cooled twice.....
Old Jan 20, 2009 | 10:43 AM
ShortStack's Avatar
Thats what id think.. and i mean.. i know its not that much more coolant, but it is more.. i just dont see how it would work out that way..
i guess im gonna go do some el-searcho
Old Jan 20, 2009 | 10:47 AM
lsjwannabe's Avatar
The reason you have better cooling with one over two is location. Look at where the stock h/e is, true you will have more coolant no doubt, but that coolant will be hotter in the stock location becuase of lack of airflow and its relation to operating temps. So your just having that second h/e cool down coolant that would not have been that hot in the first place. Also if you run one that is large enough it would make up for the capacity of two
Old Jan 20, 2009 | 11:31 AM
Thank you. I knew there was a rason behind it. lol
Old Jan 20, 2009 | 12:01 PM
OriGinaL Condo's Avatar
So would you recommend running a single H/E or inline with the new one you guys are producing?
Old Jan 20, 2009 | 12:04 PM
lsjwannabe's Avatar
Either way will work, some people perfer to leave it in for a little easier of a install. I would say if you could though take it out
Old Jan 20, 2009 | 12:24 PM
sput's Avatar
Here's my story:
I bought the cx racing H/E from OTTP last summer. When I hooked it up initially, I ran it inline with my stock H/E. I did not see a drastic drop in temps so I capped the stock H/E and ran the cx racing H/E alone and I saw slightly cooler temps in that configuration.
Also note - I was very happy with the service and quality of product that I got from OTTP. Thanks again!
Old Jan 20, 2009 | 12:26 PM
lsjwannabe's Avatar
Thanks for posting
Old Jan 20, 2009 | 10:04 PM
damnit and i just installed the stock one back up because i bought the new ott stage 1 and was figuring that it would help with cooling. i still believe it would be better.....more coolant more fins to disipate heat and yea the stock one might be in a not so good location but if gm engineered it to be there for cooling.. then obviously its cooling... then once it runs out the stock and into the front mount it should get even cooler. just my 2 cents.. but im still a noob.
Old Jan 20, 2009 | 10:30 PM
rollingboostedss's Avatar
see I don't know why you would want to have two h/e what are you going to cool coolant twice or something, now I see what you could be saying about more coolant but A. isn't cx h/e bigger then stock if not maybe more efficient in flow. B. having more coolant what’s the point the car is only going to use what it needs why have even more.
Old Apr 19, 2010 | 12:35 AM
hungryhip-ccp's Avatar
What he said. ^
old thread but im searching around for the rad coolant capacity on lsj
Old Apr 19, 2010 | 12:37 AM
troyss's Avatar
I'm running the CX racing and the stock HE also..
Old Apr 19, 2010 | 04:45 AM
Zach06CobaltSC's Avatar
Think about it like this. Take a pot and put 2 cups of water in it and set it on the stove on high. Then take another pot and put 8 cups of water in it and set it on high. Tell me which boils first? It goes back to the basics man, it takes longer to heat up more liquid then less. Running a 2nd heat exchanger or a bigger heat exchanger gives us more coolant, the more coolant the less it heats up, the less it heats up the lower our iat2's will be. Another way to look at it is how much of the coolant is used before it is being circulated back through, meaning if you only had say half of your intercooler system filled, your iat2's would be drastically higher because you are circulating that fluid through many many times. It's really late, but hopefully some of my logic makes sense to you guys =D.
Jan 12, 2016 12:01 AM
cw383
Sep 30, 2015 12:41 AM
Sep 27, 2015 08:53 PM
jmelton327
Sep 26, 2015 10:04 PM
