?? on dual pass installation - help
Old Apr 2, 2008 | 09:15 PM
QUAD442's Avatar
Question ?? on dual pass installation - help
So i am going to install the dual pass this weekend. ive got the instructions from CED which tell me to disconnect the battery, fuel rail, s/c, and intake.
Question i have is why do i need to disconnect the battery and fuel rail? i assume i can remov ethe s/c without doing this. Can someone comment.
Also, is the reason the intake needs to be removed because the laminova tubes cannot be pulled out given the clearances?? i can see the original end plate right there!
thanks guys!!!
Old Apr 2, 2008 | 10:41 PM
BeermanSSSC's Avatar
bump cause i'll be doin this soon too
Old Apr 2, 2008 | 11:27 PM
04Redline's Avatar
When i took my supercharger off only reason i removed my fuel rail was because i was replacing injectors.... I think the plate is on the drivers side of the charger.... if you take that off i would assume you would have plenty of room to remove it.... i was looking at it today.... BUMP for someone that has knowledge in this!
Old Apr 2, 2008 | 11:30 PM
outtamymind's Avatar
well i know disconnecting the battery is merely a safety precaution so that you don't accidently screw something up. and my best guess as to why you would disconnect the fuel rail and the battery at the same time is to not accidently flood your chambers in the off chance that something were to be grounded out and send power to your fuel system. thats my best guess on that one.
Old Apr 2, 2008 | 11:31 PM
04Redline's Avatar
I would definitely unhook the battery though... takes two seconds.... that's comming from an electrician... heh
Old Apr 3, 2008 | 12:17 AM
ssmokin's Avatar
disconnect the battery cause your gonna have to unbolt the alternator to remove the intake manifold. you dont need to pull the fuel rail..
Old Apr 3, 2008 | 07:20 PM
QUAD442's Avatar
it just dosent make sense why the fuel rail would come off. Has anyone been able to leave the manifold in place and swap the laminova cores??
ive pre plumbed the dual pass leaving a bunch of hose at the end to connect to the surge tank. Most people seem to route this hose across the front radiator support member and sqkeak it past the supercharger pulley. Any thoughts, comments???
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
