Dual Pass - Option B Testimonials
Old Feb 7, 2009 | 01:44 PM
  #176
BlilBT's Avatar
Originally Posted by rico
okay i have a heat exchanger ill will be installing with a dual pass. is having a dual pass only considered option 1? and if i was to get the other tank and intalled is that whats called option b? i never really understood the option a part so anyone wants to help me out? i plan to get meth with my dual pass and extra h.e but was looking into option b too. but yea whats the diff from option A and option B? thanks for the help ahead of time
Option a keeps that little neck in front of the supercharger, Option B removes the neck & replaces it with a reservoir that comes off a redline. The neck on option a doesn't allow the system to bleed the air out & the reservoir does!
Old Feb 7, 2009 | 01:46 PM
  #177
rico's Avatar
im a bit new with this. got a pic of the lil neck ur talking about? and how hard will it be to add option b to my h.e and dual pass?
Old Feb 7, 2009 | 02:00 PM
  #178
BlilBT's Avatar
See the polished cap in front of the supercharger & the overflow line, That is the stock Reservoir or Neck!
In this pick notice the new reservoir & the neck is gone, the reservoir takes the place of the neck!
In this pic you can see I didn't use the redline reservoir, I made my own. In the picture you see the reservoir for Option B, it has a 1/4 in line & a 3/4 inch out line... plus the cap has a pressure release just like the redline bottle they recommend you buy!
Old Feb 7, 2009 | 02:16 PM
  #179
rico's Avatar
oh so option b removes the front reservior and just puts a bigger one on the other side of the car? which ends up in more coolant to flow? and easier to stay cooler? so whateverline was on the stock reservior it gets transfered to the new tank? and then the other line that does out from the option b tank goes where?.. how how does it all go? from option b tank to extra h.e and then the other line to the other stock reservior or what?
Old Feb 7, 2009 | 03:05 PM
  #180
BlilBT's Avatar
Like this!
If you run a Front Mount H/E also... then you run the aftercooler line out ....too the front mount in.....Then out of the front mount too the center of the dual pass endplate like shown in diagram. This basicly puts your H/E inline, stock to utilize the fans to cool it down & then the front mount dual pass H/E to cooool it down even further & also increasing youramount of fluid...On top of all that you have a bigger reservoir that is constantly bleeding the air out of the system making the heat transfer even better.
Old Feb 7, 2009 | 03:27 PM
  #181
rico's Avatar
umm okay i see thx
Old Feb 7, 2009 | 06:57 PM
  #182
thought's Avatar
Yeah....that front cap you have now isn't really a "resevoir", think of it more as an inline filler. The option B setup replaces that with a true resevoir.
Old Feb 7, 2009 | 07:00 PM
  #183
rico's Avatar
oh so basically its replacing the cap wit a reservior and connecting the hoses from the new reservior to the hose where the lil inline filler was?
Old Feb 7, 2009 | 07:17 PM
  #184
BlilBT's Avatar
Yes it does just follow the hose diagram!
Old Feb 7, 2009 | 07:34 PM
  #185
rico's Avatar
okay good to know apreciate ur help. gonna look into doing this after i order another tank
Old Feb 11, 2009 | 12:02 AM
  #186
rico's Avatar
so out of all the diff opinions people have. im thinking of doing the h.e, dual pass, and meth set up for cooling. that sounds good or what?
Old Feb 11, 2009 | 12:13 AM
  #187
Tennpenn83's Avatar
that's about as good as you can get
Old Feb 11, 2009 | 01:25 PM
  #188
N8s07SS's Avatar
subscribed for future use.
Old Feb 11, 2009 | 08:25 PM
  #189
rico's Avatar
okay sounds good. thx
Old Mar 5, 2009 | 12:09 PM
  #190
thought's Avatar
I'm hoping to install the CX Racing H/E, Dual Passe endplate and the "Option B" additonal surge tank. For those with experience, here is the question I am wrestling with:
1) Keep the stock heat exchanger or remove it?
Keep: Easier to setup the air bleed system as there is a provision for it on the stock h/e.
Remove: Cleaner install. I can remove the stock h/e, then bolt the CX h/e in line with the other exchangers, not having to drill into my crash bar (as in the "how to"), and raising it for more clearance.
Thoughts? Experiences? =NOT(Opinions)
Old Mar 5, 2009 | 12:36 PM
  #191
Tennpenn83's Avatar
the air bleed line as described in the kit goes directly to the stock h/e
look up under the radiator support while you've got your hood open and you'll see a small cap/screw on the top about a third of the way in on the passenger side
put both in line. there's no real data from anyone that says either one is better than the other. plus its a lot easier and is still a clean install.
Old Mar 7, 2009 | 08:52 PM
  #192
fastscion's Avatar
Originally Posted by LopsidedJester
well, theoretically you can say every 20 degrees F in = approximately .5psi, and with the average conversion for psi to horsepower at 1psi = approximately 10hp. then you can say maybe 5 horsepower is picked up if you see that 20 degree difference. This is a loose correlation and doesn't have a great deal of science behind it.
I think if you have the cobra H/E, dual pass and option B you might see about 25 degrees MAX lower at WOT and much less heatsoak.
Do you have any link to show or prove this statement..?
Old Mar 7, 2009 | 10:20 PM
  #193
qwikredline's Avatar
Like this!
good explanation
Old Mar 13, 2009 | 09:27 AM
  #194
thought's Avatar
My next question is if I should be bleeding air out of the additional h/e or just the stock h/e. The reason being that it occured to me that the inlet hoses on the cx racing h/e are halfway down, meaning air could get trapped above them.
I'm going to try and replace the pressure cap with a non-pressure cap (as my option B tank has one already), then run a 1/4" hose (with orafice) from the overflow tube on the cx h/e to a "T" with the air bleed line from the stock h/e. In my opinion, this should bleed air from both.
That is, unless someone can convince me that in a pressurized system, air doesn't float to the top.....but I think it does.
Old Mar 13, 2009 | 09:31 AM
  #195
sput's Avatar
No, you're right. I use the opt. B tank with my CX racing heat exchanger. It actively bleeds the air out just like the stock one.
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
cw383
Sep 30, 2015 12:41 AM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
