Dual Pass w/ Option B & Cobra H/E installation
Old Feb 14, 2008 | 03:50 PM
rallycobalt06's Avatar
i will be installing these this weekend, and i was wondering if anyone could shed some light on how exactly i need to run the "plumbing" for this installation. do i remove the factory h/e? i have the instructions for everything else, i just need a basic run down of how to "insert" the cobra h/e in the installation.
Old Feb 14, 2008 | 03:57 PM
syP's Avatar
syP
*wrong diagram*
the cobra HE sits in front of the stock HE
Old Feb 14, 2008 | 03:59 PM
BlilBT's Avatar
Look at link below!
Old Feb 14, 2008 | 04:00 PM
that is all i'm seeing.
syP's Avatar
syP
Originally Posted by BlilBT
This Diagram is wrong!
then edit your post and take out the picture like i did
which way is the right way then
Old Feb 14, 2008 | 04:02 PM
SlowBalt_06's Avatar
i wanna run the stock h/e with the cobra. and the dual has anyone done this
Old Feb 14, 2008 | 04:07 PM
BlilBT's Avatar
Here is a link to the system setup this has been discussed alot! The bottom Diagram on the 3rd page is how it is setup!
https://www.cobaltss.net/forums/show...t=76981&page=3
Old Feb 14, 2008 | 04:33 PM
wow that is one heck of a set up. definately will be printing that out. the one thing i dont see is..... the original coolant tank.
Old Feb 14, 2008 | 04:55 PM
rnjmur's Avatar
There is no original coolant tank, just the stock HE.
Old Feb 14, 2008 | 04:57 PM
the factory coolant tank, located on the right in the engine bay when you staring at it.
Old Feb 14, 2008 | 05:33 PM
Sharkey's Avatar
the coolant tank on the right (drivers side of the car) is for the engine coolant, not the intercooler. completly different system.
Old Feb 14, 2008 | 05:44 PM
BADZSS06's Avatar
Any way to install the bypass with out removing the manifold?
Old Feb 14, 2008 | 07:41 PM
BlilBT's Avatar
No! you have to change around the Laminovas!
The 1 on the right is the factory Engine Coolant reservoir & the 1 on the left is the Option B Intercooler Reservoir!
They share nothing in common other than being resevoirs for 2 different systems!
Old Feb 14, 2008 | 08:02 PM
OOOOOOOOOOOOOH, well then this install has just got easier in my head. thanks for the information guys. you were a big help. just one last question, what exactly is the laminovas? i just want a better understand of what is exactly.
Old Feb 14, 2008 | 08:10 PM
BlilBT's Avatar
They are inside the Intake manifold >>> When you take off the Endplate they are under it!
Old Feb 14, 2008 | 08:30 PM
are talking about the rubber gasket ring? if so i believe one came with the kit. you have seriously been a big help, thanks again.
Old Feb 14, 2008 | 08:33 PM
ColeJJones's Avatar
Bannned
someone please send me a directly link to buy the dual pass with option b
Old Feb 14, 2008 | 08:46 PM
BlilBT's Avatar
when you take off the endplate there is a Green gasket>>> But under the endplate there are 4 Laminova Cores you have to switch these around! They are set in with a oring on the opposite end. The directions should have came with the endplate!
No problem man anytime!
Crate engine Depot!
Old Feb 14, 2008 | 09:02 PM
just a side note, you have the body kit i eventually plan on getting. looks really nice.
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
