Dyno Results...
Old Apr 25, 2014 | 09:06 AM
  #76
Haha. That car is NASTY!
Originally Posted by tazmanian devil
love that whine rice!!
Thank you kindly
Last edited by riceburner; Apr 25, 2014 at 09:06 AM. Reason: Automerged Doublepost
Old Apr 25, 2014 | 10:46 AM
  #77
armcclure's Avatar
I noticed that my car distorted the sound on the video and yours didn't
Old Apr 25, 2014 | 10:52 AM
  #78
574's Avatar
574
Your car was so loud it made me want to plug my ears like a little girl Thought I was gonna blow an ear drum lmao
Old Apr 25, 2014 | 10:59 AM
  #79
armcclure's Avatar
Part of that was probably the hood reflecting the wastegate sound forward. It's really not that bad on the street. Quieter at 80 than my sc setup with 2 mufflers was.
But I have been told when I go wot it can be heard 3 miles away lol
Old Apr 25, 2014 | 01:59 PM
  #80
07blackg5's Avatar
Slobodan Milošević
what exactly had to be done for the ati to fit? I was under the impression that it just pressed on
Old Apr 25, 2014 | 02:04 PM
  #81
you need to grind down some on the front (timing chain) cover for it to clear. zzp sells a modded cover which i opted for.
and to correctly run it with no chance of shearing off the keyway on the crank you need to get the keyway extended at a machine shop
Old Apr 30, 2014 | 01:47 PM
  #82
Staged07SS's Avatar
Administrator
Administrator
Awesome stuff man and great new thread!!
Old Apr 30, 2014 | 02:29 PM
  #83
phatnackySS's Avatar
Awesome stuff, iv got 165k on the clock and i'm contemplating a rebuild,this is defiantly some inspiration.
Old Apr 30, 2014 | 02:46 PM
  #84
97n06ss's Avatar
Woah! That is very impressive! Money, alot of time and motivation. My 97 camaro SS with stock LT1 and a bunch of bolt ons only made 298 rwhp and 310 ftlbs of torque. I am very impressed.
Old Apr 30, 2014 | 03:54 PM
  #85
^I re-raced my buddy's bolt on 96 LTA trans am the other day. last season we were neck and neck, and the other day i pulled about 2 cars on him from 40-100
do it! just do sleeves
thanks brah
Last edited by riceburner; Apr 30, 2014 at 03:54 PM. Reason: Automerged Doublepost
Old May 9, 2014 | 12:55 PM
  #86
Old May 9, 2014 | 06:28 PM
  #87
Nice , running alittle fat there ? real men run .80-.83 PE lol
Old May 10, 2014 | 09:01 AM
  #88
armcclure's Avatar
It's not an lnf
Old May 10, 2014 | 09:22 AM
  #89
Nice pull rice, although making me watch 2 mins of general driving first I just wanted the 0-120ish pull
Old May 10, 2014 | 10:53 AM
  #90
It's not an lnf
I know i was joking, well kinda, iv noticed on e85 i can get away with some lean mixtures but i only do it at the track. .8 isn't to crazy , i thought lnfs were higher like .86 .89
Old May 10, 2014 | 11:18 AM
  #91
Haven07's Avatar
Nice pull in that vid! Heads + cams really do wonders for our cars def going to be my next mod
Old May 10, 2014 | 11:45 AM
  #92
armcclure's Avatar
I was referring to you speaking in lambda
Makes perfect sense to use it for lnf. Lsj much easier to use afr and eqr
Old May 10, 2014 | 01:58 PM
  #93
Ahh, I do everything thing in lambda due to what seems to be a ever changing target afr due to my source for e85 floating around e80-e95 from week to week. My gauge outputs lambda and I have pid that converts to what ever the target afr of the week is.lol. lambada makes more sense to me anyway, a lot easier to understand on the fly especially when you don't quite know the actual stoich vaue if your fuel lol.
Old Apr 7, 2015 | 11:09 AM
  #94
may be dynotuning again this week on a tvs!
Old Apr 11, 2015 | 11:45 AM
  #95
Zooomer's Avatar
Supporting Vendor
Let me clear up some misconceptions and give you guys some info on the Ecotec platform.
Peak HP and HP curve on the Ecotec platform is a factor of many things.
I have seen stock cam ecotecs peak past 7500rpm. it's pretty easy with few mods but isn't always ideal.
1. The smaller the pulley, the lower the rpm for peak HP. The blower loses efficiency at higher rpms and higher boost. Therefore the faster you spin it, and the higher the boost, the lower the rpm band. In no circumstance have we ever seen smaller than a 2.7" make HP. IN nearly all builds, nothing smaller than a 2.8 makes more power. Usually you make a little more torque in exchange for less peak HP. In this build, the pulley is too small for optimum performance.
2. Timing affects peak HP a lot. With E85, you can raise timing which raises peak rpm HP.
3. Normally after peak power, the HP will decline. If it stays flat, there is usually a limitation that is just flowing as much air as it can. In this car, it's the 2.5" exhaust. Our 2.5" becomes restrictive after 275WHP (unit with resonator and muffler). It's a trade off of sound vs. HP potential and the exhaust is designed for 90% of cobalts with stage 2/3, stock M62, etc. For guys doing cams, head, turbo, TVS, our 3" exhaust is a better choice flowing 50% more.
In my opinion this build would make 15 more WHP with a larger pulley and 3" exhaust although cracking 300WHP on an M62 is impressive either way.
Old Apr 11, 2015 | 07:49 PM
  #96
Thanks for the input zooomer!
Well a 2.8 on the tvs shouldnt be too bad. In hoping to finally raise my rpm some.
idk if i feel like buying a whole new exhaust haha. Maybe one day, to get rid of all my zzp exhaust leaks :P well see what i make.
Old Apr 11, 2015 | 08:51 PM
  #97
YelCal7's Avatar
Sigh...I miss my old LSJ. SMH, DAMN YOU Rice! LOL! Great build!
Old Apr 11, 2015 | 08:59 PM
  #98
Cobalt_Daddy's Avatar
why is the forum so dead tonight?
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
footballplaya3k
Sep 28, 2015 11:14 AM
Sep 27, 2015 08:53 PM
Cptnslo
Sep 24, 2015 09:32 AM
