dyno runs.
Rent me! per hour
dyno runs.
2.5 pulley vs 2.6 on a tvs.
i'll get a better dyno graph tomorrow night.
either it's out of blower, or out of header. one of the two is limiting it. i am guessing header.
23.5 degree's of timing
11.5 afr
98 lb injectors at 79% idc.
e85
::shrugs:: oh well. not what i wanted, but close enough.
374/314 2.5 pulley
371/310 2.6 pulley
11.5 afr
e85
374/314 2.5 pulley
371/310 2.6 pulley
Rent me! per hour
box stock pacesetter header. custom 3 inch down pipe.
26psi on the 2.6
27psi on the 2.5
::shrugs:: if i had a way to run a backpressure sensor in the header i would have my answer.
26psi on the 2.6
27psi on the 2.5
Rent me! per hour
Rent me! per hour
Rent me! per hour
in a nutshell. i don't think modding the pacesetter is worth it. another 200 bucks id have to spend on a new downpipe, and labor to pull the header off. it's a bitch
Well that answers my question as to whether or not you were running out of fuel on the 98lbers. Looks like they are holding up well. I guess that is my only option as these 80s are beyond maxed. I gotta give credit where credit is due man, you are doing a great job with that tvs.
I will probably be looking for help with those 98lbers here shortly thanks again for all the tips thus far.
Tuning for 80lbers is cake, especially on e85. They actually gave me more trouble on 93 at first. Just dial in your maf and you will be fine
, make sure your stft's and ltft's are in line. They should idle like stock.
I think we should all send msgs to ottp to send area a long tube for testing and promotion.
only thing is now the s.o.b. is making want to buy a tvs.
Last edited by BeermanSSSC; Apr 19, 2010 at 11:12 AM. Reason: Automerged Doublepost
. lets trade headers u can have my clear image.
